- 8:16 AM
- Apr 24, 2019
- Waleska,Ga.
I switch between pitch on these roller noses frequently. That being said the drivers on .404 are sometimes a little bit longer as in you don't want them dragging in the bar or roller groove.It is indeed an open groove, non-sprocket roller. I didn’t know enough to call it what it was. I’ll probably give it a try. Thanks.
Can u read? Or use your eyes at all? Serious questions. Cuz your response to the original post would indicate that the answer is no.I have never heard of the expression, "You can run a bar with a chain that has the wrong pitch as the nose sprocket but the same gauge."
If there is no nose sprocket on the bar tip, "a hardnose bar", then the chain's pitch is irrelevant. Then all you have to do is match up the pitch on the saw's drive sprocket with the chain.
OP, please do not try to run a .4o4 pitch chain loop on a bar that has a 3/8" pitch sprocket nose. That's a mess waiting to happen.
I can read and average about 20 books a year. But, my eyes have been bad since I was 9 years old. Not blind, but cataracts are now driving me batty. Sorry for the error. I thought this bar nose also had a sprocket, and I must admit it's a bar nose I am totally unfamiliar with. We have had guys here ask a similar question about sprocket nose bars. Regardless, I should have avoided this thread altogether.Can u read? Or use your eyes at all? Serious questions. Cuz your response to the original post would indicate that the answer is no.
Hi Al! I’m just fond of .404. It stays sharper longer for me. I have run the 8 pin on it as well. It screams indeed.I have no idea what you have in mind but that P-100 will run an 8 tooth rim 3/8" with no problem and likely cut as fast as a 7 with .404 .
Hey , I appreciate you jumping in. I’m 70 now and I can’t see out of one eye and I’m blind in the other.I can read and average about 20 books a year. But, my eyes have been bad since I was 9 years old. Not blind, but cataracts are now driving me batty. Sorry for the error. I thought this bar nose also had a sprocket, and I must admit it's a bar nose I am totally unfamiliar with. We have had guys here ask a similar question about sprocket nose bars. Regardless, I should have avoided this thread altogether.
