Genius
First member of ASlite to receive a infraction
- 12:28 AM
- Dec 31, 2015
- Uncle Willys basement
We use the chit out of that stuff here.
why would you want that unreliable hard starting gas hoe???? "go to HF and get the predator engine...they cant be beat"getting my vj4d wisconsin i just rebuilt started
WUT!!!! You sayin a Chinese engine is good? Did hell freeze over?why would you want that unreliable hard starting gas hoe???? "go to HF and get the predator engine...they cant be beat"![]()
parently you missed the quotation marksWUT!!!! You sayin a Chinese engine is good? Did hell freeze over?
Those predator engines are not bad for the money, I have a 4000 watt genny with one and it starts easy and runs like a top. It hasn't been run a whole lot. now a hunting buddy has an 8ooo watt one with a predator and it has had the snot run out of it. never a problem and still runs fine.parently you missed the quotation marks![]()
I take it i missed something over at arboristsite .why would you want that unreliable hard starting gas hoe???? "go to HF and get the predator engine...they cant be beat"![]()
if theyre maintained, they are one of the easiest starting engines!Just bump the key and it is running ,i will keep the orig powerplant ,it must be old miltary issue ,it is drab green under the yellow paint.
2009? that book only showed up to 99It's just like 1969 except mine has a line at the bottom of the nine.
every splitter engine problem thread where most suggests to replace it with a chonda because all them old B&S, Kohler, Wisconsin's are gas guzzling hard starting scrap piles...cause ya know 50+ years of reliable service with minimal maintenance aint nothing compared to the chonda that "hasn't given any problems for the 2 years ive owned it" followed by, "when it dies, its so cheap, ill just replace it with another one"I take it i missed something over at arboristsite .
It's an old one, I've had it 30 years at least and it was my fathers.2009? that book only showed up to 99
alzheimer's would make you think thatIt's an old one, I've had it 30 years at least and it was my fathers.
well maybe but not in this case, My wife has early stages of alzheimers, it's not a good thing.alzheimer's would make you think that![]()
My skid loader i use around the house broke a piston ,when it did the rod broke ,broke the cam also ,i had a little dozer i hauled in for scrap ,the engine was full of water and locked up ,i had those jugs bored .020 ,got new pistons and gaskets off ebay for 300 bucks or so ,a buddy of mine did not charge me to grind the valves ,do the guides or bore so that was a plus ,so out of the 2 engines i have a runner for 300 plus my time ,my 1999 snorkel lift had the same engine also ,seems like a common powerplant for equipment .The old engine was tired ,had 90 psi in the good holes last i checked so it was due for an overhaul anyways ,skid loader has a lot of hours on it so it does not owe me a thing really for the work i get out of it . i have forks and a bucket for it ,the forks are great for moving logs ,and for the sawmill .every splitter engine problem thread where most suggests to replace it with a chonda because all them old B&S, Kohler, Wisconsin's are gas guzzling hard starting scrap piles...cause ya know 50+ years of reliable service with minimal maintenance aint nothing compared to the chonda that "hasn't given any problems for the 2 years ive owned it" followed by, "when it dies, its so cheap, ill just replace it with another one"![]()
