Why port?
5:13 AM
bryanr2
6:13 AM
USA
Sorry, no tattoos, not going to happen, and no pix! Only was being a smart a**.
I’m over a year into tattoo removal. Have had 14 or 15 sessions. I’m removing 8 of them. If I had known how bad laser removal hurts….. I never would have gotten tattoos in the first place.
Duce
6:13 AM
Roscommon, MI
So, that woman that tattooed her boyfriend’s name Kevin on her forehead may regret doing that?
Nutball
5:13 AM
Mt. Juliet, TN
6:13 AM
I am a newbie to chainsaws and am curious. Many people I have talked to say to get my new MS400 chainsaw ported. Why? What are the pros and cons? Really curious and trying to understand. What i have learned so far is a bit confusing.
You need to be introduced to the wide world of oil ratio and oil brands
What brand and ratio are you running?
lehman live edge slab
Live Action
5:13 AM
Mn
Stop that Stihl ultra is the only one to run. In the words of a famous YouTuber “ everyone knows that” just like saws build compression with the muffler 😂
Live Action
5:13 AM
Mn
50:1 ratio
If you have a saw ported they will want you to run 32:1 or 40:1 depending on person porting. Even my stock saws I run 40:1 because most companies will still recommend 40:1 outside the USA. The 50:1 is more of a us epa thing I think, this is not to say a saw won’t run a long time at 50:1 stock or even leaner like some run. They might not out right blow up from a leaner mix like 80 or 100:1 but I do personally believe they will die earlier than normal.
5:13 AM
Why port? Welp....I cut up a storm downed red oak today. A tangled mess it was. Used a ported MS460 with a 28" for the stem, a ported 562XP with a 20" for the smaller stuff, and a ported Makita 6100 with an 18" to work on the stuff that I had to reach up on. It was fun to be able to pull the trigger on some powerful and responsive saws, and the work went quickly. That's why we port....
6:13 AM
You're fancy
i'm lazy i only take one saw to cut everything with.
But some of these forum guy's climb everything for no reason and limb them before they cut them down
To each his own i guess.
5:13 AM
You're fancy
Buy some of these forum guy's climb everything for no reason and limb them before they cut them down
I needed to test Sammie's 6100. Usually I'd just take two saws.
6:13 AM
I ran one of these modern
Do they all suck or is just this one
Gutless and underpowered
The 261 stihl i had was actually stronger than this thing.
jacob j.
Only the weird
3:13 AM
Coastal Oregon
condom saws for the first time the other day View attachment 396832
I think that's Husqvarna's "new recipe".
