dolmarkid
- 1:29 AM
- Jan 6, 2016
- Belleville IL
You can always run a max flow
I was doing 44 to 46. I know a 576 is portly. Just like a 441. I did it all in my head and not a calculator.Like Mark Twain once said, there are lies, damn lies & statistics (he left out rounding).
Forgive me for being a #s guy, but: 76.5 - 70.7 = 8.2% increase.
Actual 576 weight 15.4 vs 14 = 10% increase. Different #s and methods will produce different results.
I have never found it hard to make a 044/440 run with a stock 460 w/o porting (do at home mods). Ported, the 460 really wakes up, and has a lot more toque. Running a 20" bar you should be very happy with the 440. Your stock 460 seems like a very strong one, so your results, and opinions, may be different than mine.
If I always bucked set up logs on a flat lawn I would not care what my saw weight is. When you are climbing through the woods, dealing with brush, steep slopes, & reaching to cut a limb, that is where the power to weight of a 044/440 shines.
It is also why I'm having a hybrid built, to have the best of both worlds.
FYI, I own both 044/440s and 046/460s, and use em all. It is not that I like one better than the other, I like them both, each has it's purpose.
That said, I prefer the 044/440s with 20" bars, and 046/460s with 24 & 28" bars. My ported 460s pull a 36" light bar very well (w RSLH), but the saw is very nose heavy with that bar on it. I'm getting an 066 partly because I believe it will balance better with than bar. A 044/440 with a 20" E bar will balance flat from the handle.
If your 044 only pulls a 20 inch bar something is wrong with it.
Good lord Dallas, don't let Al or Mike B. see it like that, it will give them a coronary!
id say that saw sat for a long time
some say i have too many saws lol
My 038 Magnum is my favorite saw in that class basically because it's the only one I have that size, got one bigger (Homelite 924) and several smaller. Mine just got rebuilt so it doesn't need cleaned...yet.
Best answerYou don't need that kind of negativity in your life!
