What's on your bench?
beaglebriar
The Peanut Gallery
10:07 PM
Warren Center, PA
Waiting on seals...
MG porting
7:07 PM
Wa
I timed the 066 jug w/o a base gasket, and I like the #s, Ex 98, Tr 122 In 80.5, but the squish is about .010, so I will need to sand the squish band.
Not bad #s for a stock jug … w/Meteor piston.
066 have always had the numbers you're looking for that's why they run stronger than the ms660 get you're squish around . 19 .21 and you'll have a grin ear to ear. :aplastao:
MG porting
7:07 PM
Wa
Yup, I'm going to sand the squish a bit and widen the top of the exhaust a bit and leave the rest of it like it is! (maybe remove a pit of slag I see in the transfers with a diamond ball).
are you holding out on picks of the cylinder MustangMike? Hummmm? :comp4:
10:07 PM
No pics, my work is not that pretty, but I did port the cylinder today, and the muffler/gasket, and Picked up the parts (piston pin clips) and will post later.
These new ring clips are tough, I launched 2 of them into outer space, have not done that in a while! (maybe they are still in the basement, but where???)
p61 western
Ol Mudflap
7:07 PM
GFY
A magnet is your friend for sure. Easy way to find small metal parts.
MG porting
7:07 PM
Wa
Lol. Yep I've got a few of them somewhere in the garage they fly and if you think you know where it landed lol not!!
10:07 PM
OK, so the squish was tighter than the solder initially indicated, so this saw is getting a base gasket. As a result, I lowered the intake a bit to make up for the gasket, + a little! Also, I checked the upper transfer by looking through the spark plug hole while shining the light in the exhaust port and got a more accurate reading. Here are my final #s: Sq .020, Ex 97, Tr 123, In 83.
You asked for Pics: Lowering the Intake, Sanding the Squish Band, Widening the top of the exhaust (both sides, hard to see), Degree Wheel with pointer.
Tor R
Novice, Leg model #2
4:07 AM
Mandal
353 G - year 2003. Got new seals, hoses, filter, plug and a OE top end.
Timings: IN77, TR 125, EX 107.
Unfortantly front handle bar was toasted, ie, damage on the heat element, gotta borrow from another saw.
10:07 PM
NW CT
You gonna be busy for awhile...
Still working on two 372s, two 55s and a couple small Husqys. I HATE waiting on parts
Oh, yeah, I just finished the 340->353 build, filled the lower transfer pocket in the cyl base extension and beveled them to around 45* to feed the lower transfers. Made about 10 cookies and it stopped oiling, the plastic oil pump melted. That saw SCREAMS! Who says 353 top ends don’t rev-up???
