460 magnum
- 10:14 PM
- Apr 26, 2016
- Very southern Illinois
Would deffinately need another crank, I believe to fix one costs way more then a new one.
Local logger likes his 576 reg carb model over the OE and NE 372's. Is his small saw for limbing etc he says.
After running it I understand why. More torque in cut.
He dont mind the weight. But I do.
you mostly need 3 sleeves, four if you plan to work through most saws Stihl & Husky have made.Thank you I had my friend make to mor for different saw's and going to make a couple more sleeves but it's on hold until the last tap comes. Lol.
Yep we figured that would be the case lolyou mostly need 3 sleeves, four if you plan to work through most saws Stihl & Husky have made.
What taps did you ordered?
Order the m12x1 LH thread.you mostly need 3 sleeves, four if you plan to work through most saws Stihl & Husky have made.
Guy gave this bad boy today. It actually started and ran, but quickly flooded out, I'm sure the carb needs a good cleaning and rebuild.
View attachment 151301 View attachment 151302 View attachment 151303
He also brought me a 372xp to work on, he had taken it to a shop, and they told him it was going to cost $500 to fix. Of course my initial thought was low compression and they were quoting him a new top end. Hooked up tester, 190 psi, not that. Rebuilt the carb, tuned it in, nothing else I can find wrong with it. I feel like I'm doing something wrong.
View attachment 151310 View attachment 151311 View attachment 151312 View attachment 151313 Seriously dont ask Y! U prob already know..... i bought a bullet and found the gun for it......still on the lookout for a NICE! 339xp![]()
190 on a stock 372? Wow. I’m guessing it was a xtorq with a base gasket delete.Guy gave this bad boy today. It actually started and ran, but quickly flooded out, I'm sure the carb needs a good cleaning and rebuild.
Any of you folks tried this?
Got another call out of the blue from a small engine shop in Iowa. Guy working on 2083. Needed plastic worm winged gear and clutch springs.
Not given up anymore plastic worm gears to we get a source for 3d making them.
Clutch springs are just husky springs on the newer clutch and I informed him.
Also told him he might be able to use the metal worm gear on the later saws that had the plastic worm gear. Anyone did this?
I know the oilers are the same. Just wondering if room since different pto seal and bearing set up.
View attachment 151212 View attachment 151213 View attachment 151214
Looks an awful lot like a 372 or 385 worm gear, might they be close enough to work?
Maybe a 266 worm set up might work?I compared a 372 long ago and it was a no go. But thanks for idea too.
Cant remember why it was a no go back then or if it could be modded to work or was worm different etc.
Lol yep the local shops here aren't worth a chit either.I once purchased 4 dead saws from a shop. They told me what was wrong with each one. They were wrong 3 out of 4!
The mechanic even demonstrated to me how a MS 460 had no compression … also had no plug or decomp!
4 local pros bring their saws to me … for one reason … they don't trust the local shops. Luckily, their saws don't break much!
