What's on your bench?
Tor R
Novice, Leg model #2
8:58 AM
Mandal
I did a bit with this one today, left to do a MM. I couldn't fix the sunfaded top cover, I should probleby try to polish it up, but its an chainsaw.
I was dumb enough to get wrong fuel line, dunno, maybe I have to epoxy the tanks: (5,2mm would be perfect O.D)
TJ the Chainsaw Mechanic
Old Homelites rule!
11:58 PM
Just finished up putting together one saw made from two. Customer bought 2 MS440s from an auction. One blown up and the other in good shape, but taken apart. Request was to make one good saw out of it. So I took the one that had a good piston and bearings and used the spare cylinder that came with the saw. Fresh head gasket and cranks seals, carb kit, fuel line, filter, and spark plug, and a Super good cleaning and she came right to life at the 2nd pull. Saw has a little air leak I need to fix, and I made a few test cuts and it does darn good.
decableguy2000
2:58 AM
WNC
Just got this gentleman finished and ready for the new owner. Should take delivery this week. Have a couple more 262's to go.
Dang, Dave where are getting all these projects from. No wonder I can't find anything on Craigslist or Iwanna, except for Poulans.
Jeremy
jake wells
no longer here
1:58 AM
ky
finally got a seal for the homelite super xl im going to change it out today.
rattler
2:58 AM
NC
I haven't had time to do anything trying to get other irons out of the fire.
PA Dan
FYD
2:58 AM
White Oak PA
I also saw that one on ebay but it looks like it had more damage that Mike's! The repair might have added a half a pound to the saw!
Tor R
8:58 AM
Mandal
My 266xpg lack serial tag, carb, top cover and start cover said it should be 1986 model, but I wanted to be sure so I pulled the top end again... crankshaft was made 86 week 49.
The few 262's I will build will be a mix of parts, like this one, uggly as hell also. This one will get an 87 carb, next one will get one 199 carb.
2:58 AM
Jason, that is a very big statement! What size bar are you running on that saw?
decableguy2000
2:58 AM
WNC
Ha. The real question is am i making any money on them. Guess i should keep better records
You don't want to do that, you'll find a new hobby. I done it with my 394 and cry every time I look at it, but it does put a smile on my face wen I run it though.
Jeremy
