What's on your bench?
Sloughfoot
6:41 AM
Norcal
Got this stuff for the mower deck awhile back. Anyone have experience with it?
ZeroJunk
9:41 AM
Browns Summit N.C.
At least I saw what the air filter looked like 😉This is how the H screw is signed
That round black cover on the side of the carb was a clear sight window on the Robin so you could see the fuel level. I let it roll over in the back of the truck and broke the window. I tried to glue something over it and it would last a short time. Finally gave up. Carb NLA.
Partner
3:41 PM
Poland
This black button only slightly wet the intake, you can do it 1 or 2 times by feel, and in the meantime I had to fix the carburetor because the fuel from the booster was flowing back into the fuel tank/Efco was bought by Oleomac, thus getting rid of the competition. There was also the same design and it was called Efco Jet 220
Sloughfoot
6:41 AM
Norcal
Partner
3:41 PM
Poland
The original Efco head and brass guides were too good, so they were replaced with aluminum
I guess the line is lengthened manually here / the spring is between the head and the gear / the same patent is in the smallest Kawasaki
Sloughfoot
6:41 AM
Norcal
Got the roof over my bench on the bench. That sycamore/plains tree/? is 30" at the base and about 100' tall. There was a bigger one next to it that initiated this endeavor.
farminkarman
I like the red & black ones
8:41 AM
Neenah Wisconsin
bulletpruf
3:41 PM
San Antonio, TX
You are a good man Scott.
Thanks. It was a long day. Brought 5 saws, but used the 026 all day. Difficult cutting; we were deconstructing large snags on the banks of the Guadalupe that could have held a body, and everything was under tension, footing was lousy, snags were full of dirt, often cutting at eye level or higher, fair amount of metal (barbed wire, tin, etc) in the snags, etc.
Didn't find any bodies, but my buddy and I cleared a bunch of snags that could have held a body, so we felt that we contributed to the effort.
We were in Center Point, which is in Kerr County and about 10 miles downstream of Kerrville. Kerr County still has at least 150 missing.
hacskaroly
2100 Fanclub Member
6:41 AM
Northern Idaho, Ehh
That is awesome that you had the tools and ability to provide service there!!
Partner
3:41 PM
Poland
The fuel line became hard as a rock, I drilled it to a larger size and installed a tygon, but this trimmer has a life of its own it has an air leak / 26 years / Here, the rubber hose was cast together with the tank gasket
