What's on your bench?
Onan18
OPE Sponsor
1:37 AM
Georgia
Got the 03 Honda XR650R running today....lotta work in that...new clutch basket..bushing...clutches....fuel system...service. Runs perrty good.
Also got a couple push mowers running and serviced today.
Ended the day working on a Honda EU2000I
It's definitely generator season, I have three EU2000Is in my shop right now.
Onan18
OPE Sponsor
1:37 AM
Georgia
Low oil switches go bad on these?
Mine runs great, but cuts out on low oil til it's warm, then it will run all day.
Not usually Dan, when you are filling it with oil ignore the "dipstick." Just fill it up until it is at the top of the fill hole. You might not have quite enough in the unit when it's cold otherwise.
1:37 AM
I wish I even knew what a 261 jug looks like, but I don't!!!
I would guess it looks like the bottom one, and the one two above it to the left!
Tor R
Novice, Leg model #2
7:37 AM
Mandal
On the good side...
346 xpg oe year 00 who looked to be a hard used saw from the outside, and I knew it needed a new slug, it was more nice inside then I had expected
Dunno how many of them I've seen like this, but it's to many! Out of what I've seen I prefer to mount the bellow on the jug first, then partition wall and clamp, then finish the rest of the boot, it's the only way I know the boot is installed 100%.
12:37 AM
On the good side...
I have drilled a hole in both tabs, and used a wire to make sure it never comes unlatched. Not the best fix.......but it works in a pinch.
TJ the Chainsaw Mechanic
Old Homelites rule!
10:37 PM
Working on a 2007 arctic cat 400 dvx. Been sitting for awhile and worse...it's shed is at the coast. Salty air has done some nice corrosion to it. Carb should clean up and rebuild ok. Rest of the bike is perrty darn clean.
Home Depot dropped off 12 mowers for us to fix up....I've done 5 and a co worker has done 4. Few more to go!
