What's on your bench?
blsnelling
Friend of the Riff Raff
2:47 PM
Franklin, OH
blsnelling
2:47 PM
Franklin, OH
TreeLife
I'm Dominick
2:47 PM
Berkshire County, Massachusetts
ranchdadmike
2:47 PM
AL
Axes are my newest thing. I've collected >40, mostly old vintage Plumb axes.
These Husqvarna axes are hand forged in Sweden, perhaps the best value on the market right now.
All three started with the same forged finish. I use a Multitool belt grinder attachment to polish them.
I've been using that particular hatchet for 4-5 years now I think..it's the perfect weight for its size and seems to be of excellent quality.
decableguy2000
2:47 PM
WNC
Husqvarna axes are the best bang for the buck on Swedish steel, I have the forest ax and carpenters ax. The only new wood choppers I bought. Both where under 75 shipped each.
blsnelling
2:47 PM
Franklin, OH
I just finished two brand new 346XPs. I've found that a ported 346XP will often go lean in a long cut due to the tank vent not being able to flow enough air. The tank draws a vacuum, and the saw goes lean. I've tried different methods of modding them over the years. I decided I wanted something different on these two saws. I started by removing the guts of the factory vent, then re-assemble with only the large outer piece. This allows it to flow plenty air, but it'll also leak fuel pretty badly when full and on it's side. That's not a good deal, since we all know about the "sideways balance" of the 346XP, lol. I posted a thread over yonder, looking for a hose end tank vent that would work in this scenario. It needed to be small, flow plenty of air, and be a true one-way valve. It turns out that Echo makes the perfect little hose end vent. Many of you probably already knew about this part, but I didn't. It's the perfect solution to my problem.
1:47 PM
View attachment 65590 View attachment 65591 View attachment 65592
Where did you get it from Brad?
Onan18
OPE Sponsor
2:47 PM
Georgia
How many do you fellers want? I know a guy. ;)
a. palmer jr.
2:47 PM
Southern Indiana
I probably take the award for having the heaviest saw on my bench today, it is a Stihl TS760 concrete saw...I didn't really want to work on it but someone twisted my arm and I think I pulled a muscle putting the thing on my bench...I don't know how those guys could use them very long..
a. palmer jr.
2:47 PM
Southern Indiana
It's done and off to the next one. I have 8 saws, 12 trimmers, 10 blowers and 13 mowers so not much time to screw off today.
It's usually the front one that gets stripped out...
Customer stripped the rear bar stud in the engine sump on a ms310. Replacing sump and seals. [emoji17]
Backtroller
1:47 PM
Land of Badgers
Brad are you still gutting the factory vent in the tank housing and then adding a piece of fuel line to tuck the echo vent in next to the carb? Just trying to get an image.
