- 7:05 PM
- Dec 3, 2015
- Banner Springs Tennessee
It certainly helped. I do not have any of those. Man those look cool!No but I added some pics above if it helps
Mine leaks there too. How you get that sum beech out of there?almost look to be the same type as my 133SG also has, same look and placement.
My bet is oil vent
Edit:
https://www.partstree.com/parts/husqvarna/saws-chainsaw/281-husqvarna-chainsaw-1990-01/crankcase/
https://www.partstree.com/parts/husqvarna/parts/501839401/
Don't remove the gear. I put a little three bond on the o ring. Drive the seal out the frontI happen to be working on one of those as well. How do you change the seal in the oil pump? Do you remove the gear assembly? Do you trust the large oiler o-ring to seal, or put a little sealant around it for good measure? That is where I stopped last night...
How about changing the seal? Do you remove the oiler gear running across it? Drive it in from the back?
Ok not exactly on my bench, heating element went out in the old dryer and I was tired of messing with it. Five year warranty made in Ripon Wisconsin, U.S.A!
Joe
Speed Queen huh? I knew a few girls that liked the speed back in the day too.
Got a part number?
