X 66 stang347 X
- 9:42 AM
- Sep 23, 2016
- Georgia
Ive used the 518 on outboards and loved it but never tried it on saws. I get dirko free so it's hard to swap
Hard to put just a little bit on, might be a little pre-set time would help a bit. It is quite bothersome to me, let alone the performance aspect, having some hanging there inside the crankcase waiting to fall off, gives me no comfort either. I've heard that(no idea of the validity) the base gasket takes up some of the shock and vibration especially on the modern high rpm saws. Seeing that they continue to defy what the older breed of saws would do, I would not be surprised if this worked out to be true. This all has me thinking that I need an engine lathe.
I use gaskets in most cases. But there are some saws that I don't like taking any more off the base than is necessary.
Yes exhaust side. I cant feel a buldge in the cylinder but that doesnt mean it doesnt have a protruding place. I am also concerning about plating.It may not be.. "Ideal" ..but if the Nic Plating around the dink is ok and there is not a burr or the wall material has not got a "upset" it should run with a new piston and ring IMO. The dink equates to a bit of lift in the roof i suppose ...dont know if the 281 when being ported works out having a bit of a exhaust lift. Is the dink on the Exhaust port ?
If you can establish that the wall "hasn't" come in "Much" or at all ..then I would think all you will get is the exhaust opening a tiny bit sooner than stock. The 281 isnt so easy to find parts for i think ? so there is that to take into the mix.Yes exhaust side. I cant feel a buldge in the cylinder but that doesnt mean it doesnt have a protruding place. I am also concerning about plating.
Got t the jug off the 281. I believe its ruined but wanted to hear you guys opinions. And yes the owner said he stuck a screw driver down the plug hole to use as a piston stop. Dumb dumb dumbView attachment 39449
expensive screw driver.Got t the jug off the 281. I believe its ruined but wanted to hear you guys opinions. And yes the owner said he stuck a screw driver down the plug hole to use as a piston stop. Dumb dumb dumbView attachment 39449
Probably raise a little ,and grind out that dent...[emoji2]Yes exhaust side. I cant feel a buldge in the cylinder but that doesnt mean it doesnt have a protruding place. I am also concerning about plating.
