What's on your bench?
5:37 PM
OK, Close Ups:
5:37 PM
Pulled that stupid saddle to get the close up pics, was trying to hold the phone camera in one hand and a light in the other, and ripped my finger open on the felling spike! Paper towels were close by, and controlled it.
Hey, that saddle is not T-27, it is T-20, guess they don't want you removing it. Surprised I did not have to "break free" either of the bolts holding it, but they were snug and seemed to have mild resistance all the way out.
5:37 PM
I'm thinking if the tolerances are real close and the piston got over heated, it may have touched. I can't find anything else to blame!
5:37 PM
I don't know how to save it, but when I expand photo #1, I can see a slight dent at the end of the nipple, and "damage scratches" on the inside of the case above it. I can also see them in photo #3, but it is blurry in that one.
I'm now all but sure this is what happened.
5:37 PM
Not totally unscathed, and a hot piston at 15,000 RPM may be very brittle.
5:37 PM
OK, then why did this happen?
I just checked it again. If you look straight down, perpendicular to the base, the nipple does protrude a bit. If you take a straight edge, go across the bolt holes in the cylinder to see where the piston would be, then a straight edge across the bolt holes in the case, it is very, very close.
I'm not convinced it did not get hot, expand a bit, and contact it. You need about 20/1000 gap in the squish to make up for expansion, and the dome is a lot closer to the pin.
I'm not sure that I'm right, but I will tell you, the tolerances are very tight.
I think before I re assemble, I will block off the crank with a piece of paper and take my 12V sharpener with a diamond stone and take it down a bit. It can't hurt.
VinceGU05
one day when i grow up...
5:37 PM
S.E Australia
i still dont like the look of the color inside the case. crap mix or fuel used i think. thin aluminium would deform and not break up if only touching it. if it was to hit the nipple by a 1mm plus i would say yeah for sure. i am still going with my original thoughts.
