What's on your bench?
ZeroJunk
12:44 PM
Browns Summit N.C.
That’s a lot of dead blowers 😳
Well, two sprayers were broke where about a 2 inch round by 1/4 steel ring snap in to the bottom of the back plate to hold the strap . Stihl makes a kit to repair that. Another was broken where the top strap goes through and has about a 1/4 inch straight steel rod that snaps under two hooks. Those sprayers take a beating. One sprayer the control valve in the handle was stopped up with some nasty crud. One of the plain BR600's needed a carb.
Most of the rest of it was just won't crank. Either flooded or not pulled enough. MS661 needs helicoils or timeserts in muffler holes. HT135 needs a shaft bearing. I hate those things.
11:44 AM
Powerstroke Cowboy
10:44 AM
Montana
lehman live edge slab
Live Action
11:44 AM
Mn
hacskaroly
2100 Fanclub Member
9:44 AM
Northern Idaho, Ehh
is the choke rod all there, or is it missing some sort of knob?
It appears your choke rod is complete:
There are other documents for the 070 which is just about the same thing that has a knob on it's choke, possibly same as 080 and 090 too.
There is a thread on the forum which has links to the service manual and the IPL (in German).
hacskaroly
2100 Fanclub Member
9:44 AM
Northern Idaho, Ehh
I am taking a few minutes away from the workbench to work at my computer drawing out a crankcase gasket for my Husky 55. Once I get this done and cut out on the Cricut I can work on getting that saw together. I also need to draw one out of for a 365/372 as I have one of each of those that will need one. Once I get it all blocked out, then I will go back and round off all of the corners.
hacskaroly
2100 Fanclub Member
9:44 AM
Northern Idaho, Ehh
About 40 minutes later I have finished with my first draft. I will cut this out on regular printer paper first and do a test fit. I will make any adjustments to the drawing needed and then to a test cut on card stock. If all is well, then I can start cutting this on gasket material, if not, then I make whatever adjustments are needed and retest.
11:44 AM
That's pretty cool.
JKNW
9:44 AM
Washington
What are you doing the cutting with? I've been fooling around with Fusion the last couple months, reproducing some of the gaskets for these old saws would be a great use for it.
hacskaroly
2100 Fanclub Member
9:44 AM
Northern Idaho, Ehh
I use the Cricut Maker, for cutting out my test paper and card stock gaskets, I use the small blade, however when it comes to cutting gasket material I have to use the larger blade. It takes about 7 passes to fully cut through the gasket material, but only takes a few minutes all together. It ends with nice clean cuts and is quite accurate even with small stuff. I did some Zama carb gaskets and it cut the little locator holes without any issue.
oddsaws
11:44 AM
Bartlett TN
550 mk 2 stripped down. I don’t have to split the case on this one and I don’t have a splitter for the 5 series. Any good aftermarket tools or secret methods to split a 5 series case?
Follow up - crank splitter
I whipped up a quick technical drawing on some bolts to use with a Lilse steering wheel puller. My wife works at a machine shop and they did me a favor. Going to test it out shortly.
