What's on your bench?
5:48 PM
Well, technically it was on my shop floor most of the tinker time.
I fixed & upgraded this cutter for a good friend.
The red pipes were the OEM ones, they failed so I replaced them with thicker walled and longer ones.
Function tested on 10mm/.38" steel.
The jaws are rated for up to 18mm soft steel (up to 15HRC) and 13mm alloyed steel which is quite impressive.
The only difference is the OEM supplied pipe/handle length.
11:48 AM
It was breaking up like a bad sparkplug
turned out the ignition module had come loose and was arking fire
he likes to tinker so i don't know
If he did it or not
And a new pull rope the original was very short and a pain to start
Cutting the collar off the stihl tuning screwdrivers makes good 2 series adjustment tool's
Good running saw.
nbbt
10:48 AM
5543X, 5644X
After a bit of cleanup I got it to pull fuel and almost run correctly. I'll add a new metering / and pump side diaphragms and give it another go.
Oiler is not pushing anything at all.
Has anyone have any experience with this little mighty beast.
I'm trying to get it going for a good buddy without getting to deep.
@ray benson or others do you have an IPL and / or manual for this monster?
jacktheripper
Papa Squat
9:48 AM
Wyoming
Converted my 038 Mag II that I bought from @how57 with chinese short block into a genuine Stihl saw with parts from @Woodwackr tonight.
jacktheripper
Papa Squat
9:48 AM
Wyoming
Time to work on the straight-gassed 261 that I bought for $50.
