What's on your bench?
Tor R
Novice, Leg model #2
5:47 PM
Mandal
My 238 parts saw is getting interesting, this was on the edge down to the crankcase, perfectly positioned to not fall down, it is less a part for the piston that has disappeared. What is missing has been chewed up.
nbbt
10:47 AM
5543X, 5644X
Picked up this non-running Lawnboy, with a suspected bad coil.
Started by giving the mower a bit of a cleanup as it was rather dirty oil soaked.
Replaced the coil with a used one that was saved from a piston/cylinder scored mower.
After reassembly it started on the 3rd pull. Noticed right away that it was spitting dirty oil spots from the lower crank seal area..
Found that someone had previously replaced the seal with the wrong style and it had ejected itself.
Had the right dual lipped one with the steel outer case in my spare parts supply and did the swap.
While the muffler cover was off to get to the seal for replacement, cleaned the exhaust ports . One was about 20% carboned and the other two had smaller amounts.
Back to seeming to be a great running mower.
I like this series partly because it has a metal carb that has an external fuel adjustment needle screw.
farminkarman
I like the red & black ones
10:47 AM
Neenah Wisconsin
image.jpgimage.jpgimage.jpgimage.jpgHere is my Echo 490 I donated for the raffle at @Stump Shot ‘s GTG. This is headed to @LAWN BOY compliments of @bradb123. I ended up cutting the base, raising the exhaust and transfers. I did a simple muffler mod and removed the limiters from the carb. Since I had an extra K095 bar, I modded it to fit and will be sending it along as well.
LAWN BOY
Pothole
8:47 AM
Merrill, WI
View attachment 438506View attachment 438507View attachment 438508View attachment 438509Here is my Echo 490 I donated for the raffle at @Stump Shot ‘s GTG. This is headed to @LAWN BOY compliments of @bradb123. I ended up cutting the base, raising the exhaust and transfers. I did a simple muffler mod and removed the limiters from the carb. Since I had an extra K095 bar, I modded it to fit and will be sending it along as well.
Nice. Looking forward to it. Thanks again guys.
Member
10:47 AM
