What's on your bench?
cease232
5:30 AM
Montana
Ridgid planer with a bad switch.
Tor R
Novice, Leg model #2
11:30 AM
Mandal
get a batch oem parts next week, figured out it was best to spend my spare time propleby ;)
254 crank, jugs is 87, 89, 91, 01
This saw will have air injection, if I want to use one of the two old jugs, I have to cut the fins a bit.
rattler
5:30 AM
NC
Tor that wheel looks familiar
skippy
Husqvarnas Sawyer
5:30 AM
Pennsylvania
I can't wait to have my bench clear off to begin my chains for the chain off .
Finish the 281 and my buddy's oh24 .
TJ the Chainsaw Mechanic
Old Homelites rule!
2:30 AM
MS460 that a logger brought in. Guy was so smart that he let a buddy adjust the carb for him to make it run better. I guess 15000 RPM on a stock 460 is perfectly fine right? Right........
Dug into the carb and found that the need was sticky.....gonna sonic tank the carb then let it dry and then soak wit carb cleaner. Outta get the goo out of the needle hole....cause I can't see it. Then I will kit it and hope that a new fuel line, filter, spark plug, and proper tuning will solve the issue. Saw is in great shape, just have a loose nut behind the bar.
