What's on your bench?
Woodslasher
Teh debil
3:34 PM
Commiefornia
Why do I always put new bearings in a carcass I'm building? Because even though they may roll real nice they can still be dirty. Most of the hybrid 660 parts I've been waiting on showed up tonight, but I'm a slacker so there's not going to be any progress any time soon.
hacskaroly
2100 Fanclub Member
3:34 PM
Northern Idaho, Ehh
On my 272 I have one that rolls really good and one that is a little "stiffer"...I should play it safe and just get new ones while it is still split apart.
12:34 AM
Dolmar PS-550 muffler, part of the baffle broke off (the little piece on the top right) and rattled within the muffler.
Not chancing it finding its way into the combustion chamber, full muffler mod is underway.
Kiwioilboiler
346 Pic Examiner
10:34 AM
Marsden Pt, NZ
Check out redline4 latest stihl build for a hot tip from Stump Shot on those type of mufflers Willhelm..
12:34 AM
Thanks, but I will finish it tomorrow.
I want to open the OEM outlet just a tad more, no secondary!
Cylinder will not get touched, above my pay grade!!!
12:34 AM
Where do I find that build thread?
I am illiterate finding anything Stihl!
markds2
10:34 AM
Nelson, New Zealand
My freind sent me a MS661c 'that wouldn't turn over'. Ominous signs on opening the muffler:
I think he has a problem with aluminium eating rodents:
And rebuilt with new meteor piston, air deflector, and pto side oil seal. Cylinder cleaned up OK luckily. Friend is extremely happy to have it back so quickly as he was intending to cut wood with it over the Christmas break.20231220_203700.jpg20231220_213424.jpg20231220_213429.jpg
hacskaroly
2100 Fanclub Member
3:34 PM
Northern Idaho, Ehh
That is awesome to hear. I have been surprised by a few cylinders that I thought would not make it, but clean up enough to have a second life!
12:34 AM
I think this is the one he is referring to:
Ugly Stihl 064 overhaul
Link don't work, but found the thread thanks to the title
Nate.
3:34 PM
Northern CA.
View attachment 401305View attachment 401306View attachment 401307
I’ve thoroughly washed many bearings that looked like that and never had one fail on me. To be clear if I’m rebuilding a saw for someone else it gets new bearings. But not a single one of my saws has ever received new bearings and I’ve never had one fail.
6:34 PM
2016 ford flex 180k bad wheel bearing
Steel bearing housing seized to the aluminum carrier
Broke 2 shop hammer's
Before notching the bearing and using bolts to push the bearing off
Twas a *b-word.
heimannm
5:34 PM
Dike, Iowa
I don't remember if I posted any of this here already...local tree service outfit is pretty hard on saws. The owner dropped off 10 a few weeks ago to see what could be done. There was one more top handle saw that didn't make the photo.
The 038 just needed a good cleaning and some minor repairs, the 362 required a carburetor kit and some small items, the two 261's both required carburetor kits, one needed the buffers for the air filter base, both needed sprockets, from the 6 top handles I was able to make 4 runners, one missing a muffler and clutch cover but he said he had more broken saws in the barn.
Mark
hacskaroly
2100 Fanclub Member
3:34 PM
Northern Idaho, Ehh
What is your process to wash them out and prep them for reinstall?...I am willing to give that a try since it is my saw.
6:34 PM
Bought my 700.00 2006 4x4 Silverado a year ago i haven't driven it since spring
I put it on the road this week
The front brakes were making a grinding noise like they bad under brakingIMG_20231222_110219.jpg
Has new brakes just a few hundred miles on them
I found the receipt in the glove box
Bi metallic brakes grind some i guess.
I'll resurface the rotors
Brother's yukon died so he gave me 4 new tires less than 500 miles and the wheels
I have to replace a stud on my truck.
