What's on your bench?
Ketchup
Epoxy member
1:00 PM
Colorado
I have used aftermarket 372 cases before, but not lately and will not in the future. Seemed too porous, breaking easily at inner spike bolts. If you need a clutch side half, I have a used one.
The first one I tried to use had voids in the metal that were painted over. I found them when I pressure tested. Never touched another one. They might be better now. Or not.
farminkarman
I like the red & black ones
2:00 PM
Neenah Wisconsin
Just curious, how long ago was that? I used a PTO side AM case to repair an X-torque last year and the saw is still running. It is used by a local tree service, but I don't believe it is a primary saw fwiw.
2:00 PM
I don't need one. I was just wondering about the quality. On this one you're working on now....is the crank undersize, or is the bearing wallered out?
2:00 PM
So.....like the rest of the Chinese aftermarket garbage. Sad.
Duce
3:00 PM
Roscommon, MI
Bearing looks bad, probably would have worked if they had used sleeve locker. I have a spare crank if needed, ordering parts now. Pretty complete saw, compared to what he usually sends. Getting tired of cleaning dirty saws, you know all about that.
2:00 PM
Gonna make a nice saw for you. I have MS400s on my bench.
farminkarman
2:00 PM
Neenah Wisconsin
A couple months back I ported a brandy new MS362 for a member on this site. When I did the initial test cuts it seemed a little lean after it got warmed up. I figured the m-Tronic would take care of things so I sent the saw on its way. Well…the m-Tronic didn’t or couldn’t compensate for my port work. So I had the saw sent back. I took the carb apart and found the opening in the seat was only 0.023”. The feed holes for the solenoid and the main nozzle were ~ 0.045”. As a first step, I drilled the seat out to 0.033”. I just ran a tank through the saw and it seems to have fixed the issue. I will probably run another tank just to be sure, but figured I would post here in case others have had similar issues. 744092E8-A56D-4FC7-8126-4278457EF462.jpeg8C545158-B868-4CB9-A85D-1231F9CE6544.jpeg
