Kiwioilboiler
346 Pic Examiner
- 5:04 AM
- Apr 20, 2020
- Marsden Pt, NZ
I think helps with drill speedand what is the vertical stabilizer at the very top of this drill?
Any of you legends know what thread Husky uses for the travel limiter av buffers at the lower rear of cases?
It's coarse, and not anything in my tap n die set.
IPL # for the "screw" is 503 215 101.
Screws I got Simon, but the 357s I'm building have wallared out the case thread for them. A great pal will try and weld the holes up a bit, and then I hope to recut. I'll break out the tpi gauge tomorrow.That Husky part number is 503 21 51-01. Looks like it is part threaded coarse pitch M6, but it could be a non-standard thread like a self-tapping screw or something.
I've shown an image from a UK supplier as it has the best photo and a link to an Australian supplier. Couldn't see a NZ supplier after a quick search.
https://www.allmowerspares.com.au/husqvarna-genuine-screw-6mm-503-21-51-01-503215101.html
You will need bigger nozzles for the wand if you went with a bigger pump. There are a few different size Turbo nozzles. (0° spinning nozzle)More on the pressure washer .The replacement pump has 50 percent more volume going from 3 GPM to 4.7 GPM at 3,000 PSI .If I crank down the pressure regulator the spinner sounds like a jet turbine but it really lugs the engine . I was afraid of breaking a crankshaft so I backed it off . I'm thinking with that in mind it would be more suited for about 10-12 HP .At any rate it really gets with the program with the replacement pump .BTW a little shot of Stabil in the fuel must have cleaned up the fuel because it doesn't miss a beat now .Think about it .It's about like a weed wacker .Use it 4-5 months a year and the rest of the year it sits .In Florida things might be different but this is Ohio and it does get cold at times .
Could you helicoil it m6x1 then take the threads off the end of a 6mm bolt to look like that bolt but with a m6x1 thread?Screws I got Simon, but the 357s I'm building have wallared out the case thread for them. A great pal will try and weld the holes up a bit, and then I hope to recut. I'll break out the tpi gauge tomorrow.
Defo. That's the backup plan.Could you helicoil it m6x1 then take the threads off the end of a 6mm bolt to look like that bolt but with a m6x1 thread?
If there is enough meat to tap it to m8 you could use a m5 thereaded insert and a limiter bolt from a 372.Screws I got Simon, but the 357s I'm building have wallared out the case thread for them. A great pal will try and weld the holes up a bit, and then I hope to recut. I'll break out the tpi gauge tomorrow.
I've wanted one of these for a while, one finally came up on eBay at a reasonable BIN price so I jumped on it. Turns out to be in great shape with compression like you rarely find on a used concrete/cut off saw.
Mark
What is the rotation range? has any plaques?Teraz jest w domu. Myślę, że to Rzemieślnik z 1942 roku. Brzmi gładko. Nie wydaje się nie do końca zaokrąglony. Uważam, że oryginalny kolor to ciemnoniebieski. Może tej zimy robię renowację
Jest dość wysoki, to 36-calowy słupek Stihl wiszący View attachment 338841View attachment 338842
