What's on your bench?
Landmark
Chainsaw Hack
2:08 PM
WNC
image.jpeg Finally got the new oem top end installed. Pressure and vac tested. Generator, flywheel, and heated handles installed and new xpg carb assy all courtesy of @Tor R
Added a xpg decal. Then fired it up and got it to start idleing. Next will be getting it into some wood and see how she does.
Tor R
Novice, Leg model #2
8:08 PM
Mandal
View attachment 28774 Finally got the new oem top end installed. Pressure and vac tested. Generator, flywheel, and heated handles installed and new xpg carb assy all courtesy of @Tor R
she i look great Dave!! Did you used the carb I shipped to tou, or just the heat element?
And did you dremel the top cover?
Me waiting report how you like it compared to 262 ;)
Cut4fun
Redneck Chainsaw Repair
2:08 PM
Ohio
I'm setting up my little ms200t killer for 8" cant racing.View attachment 28770 View attachment 28771 View attachment 28772
We kept the rear handle 40cc under class separated from the top handle saws. TH class we called bumblebee class.
2 cuts 8x8 TH's were at a disadvantage as it was with handling in cuts etc as it was. Dont ever recall the ported TH's coming close to beating the ported 40cc under rear handle saws.
Man I wish we would have had PS PS3 chain back then. :campeon:
Landmark
Chainsaw Hack
2:08 PM
WNC
Thanks. I used the carb you sent. I didnt dremel the top cover. I did a mild mm. Will do alittle more later. I will report in after i get a few tanks through her but if it runs with my 262 i will be shocked. But i know it will be a good runner.
Tor R
8:08 PM
Mandal
I fancy those 550, me think it's the best 50cc ever made.
It was one AT-1 carb, far as I know there was less issues with them compared to the later one AT-7.
If you dremel the top cover your jug will get better cooling.
Tor R
8:08 PM
Mandal
Let's talk about that cover mod Tor.
More info please?
cylinder cover # 587 24 86 03, one hole added and a wall has partly cut out to improve air flow according their service bulletin, s/n 2015 48 00241.
Think the same has been done to 560/562 also.
The one hole isnt that long distance away from the decomp valve, but what they did inside I dont know
Tor R
8:08 PM
Mandal
Tor R
8:08 PM
Mandal
panteliss
8:08 PM
Europe
Go to someone who have laser engraving machine , its better than the dremel and cost nothing and the result is perfect
panteliss
8:08 PM
Europe
Just an example of laser engraver on chainsaws
Canadian farm boy
“Normal” people scare me.
2:08 PM
Ontario, Canada
That's cool. Man I like that. My imagination is spinning right now. Just think of the things you could do.
Just wondering about the starter handle. It appears to be MIA. Kinda looks like it's got a push start button now
panteliss
8:08 PM
Europe
Deets066 have post a thread about this saw if i remember good , i just put the picture about the laser engravers
