What's on your bench?
Woodslasher
Teh debil
11:28 AM
Commiefornia
Well, the 350 from hell is back on the bench. I wanna punch the dummy who designed the clamshell-normal cylinder hybrid. Right now I'm running in circles chasing an air leak, I think. When I got it the saw would fire right up, but it would just start screaming. I tracked the leak down to the fw side clamshell and re-sealed it. I also put in a new carb kit and a new piston, but the saw still just screams. It won't even begin to hold vacuum, but pressure only shows me I need to come up with a better system for blocking off the intake and exhaust. I thought I had a breakthrough at one point, but it turned out I'd just accidentally pushed in the decomp. :facepalm:
To expound upon my discovery, I made plates to block off the intake and exhaust figuring they'd do a better job than my using the carb and muffler heat shield with a piece of duct tape behind them. That fixed the exhaust leak but the intake still leaked. I checked my plate and realized it was a little wavy, so I trued it up but it still leaked. I was pretty close to tossing the saw in a corner and moving on when it hit me, the intake was the only spot that leaked! And earlier I blasted the fw side with carb cleaner and the intake region too by accident and the saw stalled! So I'm pretty hopeful that this will fix it, and even if it isn't the only leak it should fix it enough to point me to the next one.
WillG
2:28 PM
Norwich CT
Not much. Delivered the sw4200 and that was it. Was a bit warm on the way home from work today.
kingOFgEEEks
2:28 PM
Tioga County, PA
Asplundh and Lewis run those small saws for slashing here. It’s not logging, mostly just brush and small stuff. They maintain the power lines/right of ways for the power company. I used to work for Asplundh and it wasn’t a fun job. Lol
Where saws go to die...
Lightning Performance
2:28 PM
East of Philly
That's how I used to do heads for hopped up street cars. The 80 grit kept the velocity down a bit while the porting added the volume.
On all out drag cars, a slightly finer grit like 120 was used. Would this hold true on all out race saws?
It's more geared toward creating a thinner boundary layer by creating small turbulence on the port walls. That reduces drag.
I use 60-80 grit on intakes, any intake system. The exhaust can be polished just like combustion chambers but 120 then some beat 150 paper and I'm done. Others will disagree but carbon covers most of it right quick if your not running alky. Polishing exhaust ports only helps remove heat a bit more by reflection imo. Pointless on the street but for giant turbo cars.
Sagebrush33
2:28 PM
Upstater
A polished surface has less area. Less surface for heat soak and more velocity to get that heat out.
Sagebrush33
2:28 PM
Upstater
WillG
2:28 PM
Norwich CT
Nothing this weekend or next week. Taking care of some things in the house plus I want to get some cleaning and organizing done. Enjoy the holiday weekend everyone.
2:28 PM
So on Wed the 461 Meteor piston came in, and I got that running and back to the tree guy.
But yesterday I did something more important, went up to NH to visit my new Grandson Alex! The Mustang got 24 MPG!
