What's on your bench?
Chris Zautner
10:00 AM
New York
10:00 AM
To start off with I finished off my 660 after being raped for parts.
Then on to the 084 which is in for major surgery. 3/4 built then onto the 394.
Finally got the new rim and sprocket and fitted that up. Ready for action.
Then tried my hand at some square filing of a chain
Not bad, but you got a little bit of a beak. It will cut just fine, but won't stay sharp quite as long. Try to line up that outside corner.
TJ the Chainsaw Mechanic
Old Homelites rule!
7:00 AM
Got two Echo Bear Cat IG-3500E's going today. Customer just purchased them last month and was already having issues. 1st one was a clogged fire screen. 2nd was a loose connection to the ignition coil which is a factory screw up. Another issue the 2nd one has is a cross thread spark plug hole from the factory as well. Time to do a warranty! Oh wait...parts aren't even made yet because it's to new! :BangHead: Also gotta mower I got running sitting by my bench as well. Should be out the door tomorrow morning.
10:00 AM
yeah .. some i nailed.. some i didnt.. got to control my file angles a bit better and inspect more often. :)
I put a stump vice on the bar and put the saw on top of a wooden box I made that has 45 degree lines on it. Helps me to keep my angles correct, just keep the file parallel to the lines.
Onan18
OPE Sponsor
10:00 AM
Georgia
About Kohler. Does anyone make an after market rebuild kit for the twins? Kohler kits make me woozie their so expensive.
None that I am aware of that are worth it, I rebuilt a K181 with a kit from eBay, it made it six months and started knocking. Took it back apart, put in a genuine Kohler piston and rod, and been good to go ever since, five years or so now.
Joe
10:00 AM
The Mustang 2.6 Cube
exSW
'Cause Thomas is a poopyhead
10:00 AM
United States
Joe
I have a KT 17 that needs rebuilt. Just can't get past the kits cost.
