Backtroller
- 8:42 AM
- Dec 31, 2015
- Land of Badgers
Dibz on the dog chain hasp and hand grenade...Cleaner......
You want the F-Bomb too?Dibz on the dog chain hasp and hand grenade...
Nah. I got lots of themYou want the F-Bomb too?
2260 just died in the cut. Started back up once DOA since. Will hit if fuel down the plug hole. Piston still looks perfect. Fw is in proper position. Has strong spark.
Autotune carb is not getting any fuel to cylinder.
Took carb apart and will run a cycle or two in the UC.
This saw has a curse
I took it to cut last week and it had popped the primer purge line off the back of the bubble.
When she runs it is a mean saw.
It just doesn't run enough.![]()
I’d trashcan the black filter too. Stick with flocked or orange mesh on those saws.
There a winter filter that lets fines in for normal cutting. Even the yellow “summer” mesh filter sucks in my experiences. It’s why they came out with the updated finer mesh orange filter.Whys that?
Thanks Joe.Want a new carb Travis? If so PM me the Serial Number and coil part number.
372 and 390, The 372 acts funny after about a half a tank and won’t hold a tune, according to the owner I’m assuming it’s a tank vent issue, the saw starts and runs fine with a re-tune, The idol does go a little higher everyone once and while after several hard revs but not always , And the 390 is severely scoredI’m assuming it’s a tank vent issue,
Check the intake and pulse/fuel line's for a leakView attachment 189234 372 and 390, The 372 acts funny after about a half a tank and won’t hold a tune, according to the owner I’m assuming it’s a tank vent issue, the saw starts and runs fine with a re-tune, The idol does go a little higher everyone once and while after several hard revs but not always , And the 390 is severely scored
My first thought also, but if not could be seal or coil (or plug or fuel filter).
And the mating surfaces to the carb to make sure they're flat.
