- 1:03 PM
- Dec 30, 2015
- Brewster, NY
Good info on the testing, thanks.
Obligatory scored piston cylinder pic from the 390!View attachment 189279View attachment 189280 View attachment 189281
It looks like the scoring is through the plating
The rod has a fair amount of side to side play, and it feels like it has just a touch of up-and-down play
Tried with and without fuel filter, with and without tank vent. Won't even hit . All after cleaning an already clean carb.Want a new carb Travis? If so PM me the Serial Number and coil part number.
Did you blow through the fuel line? No cracks in it?Tried with and without fuel filter, with and without tank vent. Won't even hit . All after cleaning an already clean carb.
Still no fuel getting to the cylinder. Plug completely dry.
I guess Same thing that makes autotune awesome, make it suck.
Can't find one crack at all seems really good shape.Did you blow through the fuel line? No cracks in it?
Pissing me off
I did this and it will hit until mix gone from cylinder.Try this. Bypass the carb and squirt mix through the plug hole or the through carb with throttle open. Then see if it will fire off.
