What`s not to like about the 372xp? X-Torq and Non
mdavlee
Hillbilly grinder
3:32 AM
TN
They're close on squish. I don't believe there's any changes I seen from the 2166 cases I used to build a 2165 out of to the old 2065 cases from 1997
porsche965
3:32 AM
N.E. Ohio
My ported Xtorq 365 (same as a 372xt once the baffles are cut out) is turning at 14,200 on the edge of four stroking on 50:1. Probably close to 35 tanks or so over the past 3 years. Great saw.
Runs like a champ.
jockeydeuce
12:32 AM
BC, Canada
My gut says whatever changes there are, will be subtle enough to work....Same part #'s other than the suffix # after the dash...So hoping it's just a subtle update of some kind...I'll know for sure in a day or two I guess...lol
pro94lt
2:32 AM
South
Screenshot_20170124-175717.png Screenshot_20170124-175721.png372xp oe, 365xt both HD filters, tops factory dual dogs, 28 inch bars if I remember correctly and the XT had full comp chain, the 372 had skip. I'd also say the XT handle bar is a few oz heavier too it's definitely wider where the av spring bolts up, so the weight difference is at most what you see on the scales... if you truly wanted the weight difference you'd even need to weigh the starter handles as the older OE 372s came with different handles. Lol I like them both. Has anyone weighed the pistons XT vs OE?
beaglebriar
The Peanut Gallery
3:32 AM
Warren Center, PA
Sorry to kinda hijack, but a guy just dropped off an X-torq with a broken case to fix....Is it backwards compatible with the XP crankcases??
X torq cases are the same but different. The relief for the lower transfers is a little larger on the x torq if I remember correctly.
