SOS Ridgerider
Muffler Modded Member
5:02 PM
Central CT
Does the cap screw down tight @SOS Ridgerider
If so I’ll just buy by the gallon and take that with me to the pump. My ratio right cup doesn’t have a lid
That fastens
It's ok. I wouldn't say it's spill proof. Tight enough to swirl the gas around in it to mix the last drops of oil with a splash of gas, but not tight enough to really shake it.
If left upright and stable I'd be comfortable travelling with it. Laying on its side or upside down it'll definitely leak.
Wood Chopper
So so sleepy....
5:02 PM
Mechanicville NY
Good enough for the cup holder in the front seat!!!
Haha
shadco
Ban Hammer Custodian
5:02 PM
City of Oaks, NC
Using Ratio Wrongs since the early 70's
5:02 PM
I've never run richer than 40:1, but Saber at 40:1 lubricates just great, so there is no need.
Others have reported problems with M Tronic with richer mixes, but I believe is was oil dependent (some oils were OK richer, others not).
I just use what works for me. I have had builders rip down my saws and say there were well oiled, that is all that matters.
Deets066
AKA Deetsey
5:02 PM
It is mostly depending on tune. If you tune yours saws a bit on the rich side, then 50:1 is even sufficient.
Nutball
4:02 PM
Mt. Juliet, TN
Tired of measuring your oil? Don't know when to use 32:1 vs 50:1??
Take out the guess work and
JUST USE 70:1!!
At least it's easy to use 2 for 35:1
BTW my Echo bottles had consistently just under 2.5oz, so either my measuring cup is off, or they're shorting me.
