brandonstclair20
12:48 PM
Starkville
I mixed up a batch of klotz and it was red coming out of the bottle, but the mix was just a little darker than straight gas and it was not red.
12:48 PM
The gas pump could also vary a little bit. How much? I don’t know and it doesn’t really matter. Sometimes when you pull the trigger a little residual comes out left over in the hose before the pump starts pushing gas out. I just try to stop it once it gets to 1.990 range or so when I’m making 2 gallons of 40:1. Not worth overthinking it.
Billy Currie
12:48 PM
Asheboro, NC
I waited an hour to get the number I got. I don't think the bottle I took a picture of ever had enough in it to make 2.6 oz.
I have rinsed out the bottles as well with fuel to get the last bit of oil out, but that only works when you know you have started with the correct amount of oil in the container. After gas has been introduced there is no way of knowing the quantity of oil you put in.
12:48 PM
From experience on some of the gas cans I’ve used there sight lines are liars. For example a gallon filled by the pump meter would be lower than the gallon mark on the can by a significant amount. So either the pump was off or the can was off lol.
Nutball
11:48 AM
Mt. Juliet, TN
I've had a pump cheat me big time filling a car/
There could be: a hydrometer type device and some chemical analysis info on the gas and oil used.
Wood Chopper
So so sleepy....
12:48 PM
Mechanicville NY
Real oil bottles are clear lol.
brandonstclair20
12:48 PM
Starkville
Has anyone used this? I wonder if it blends with gas?
It might be their only 10, 10, 10 rated oil.
I mixed up some super techniplate and it did not turn the gas red. I was afraid to use it but I was certain I put the oil in it.
Wood Chopper
So so sleepy....
12:48 PM
Mechanicville NY
+1 on this one. This what I do. I even have that very mixing cup.
Does the cap screw down tight @SOS Ridgerider
If so I’ll just buy by the gallon and take that with me to the pump. My ratio right cup doesn’t have a lid
That fastens
