jmssaws
Banneded
7:06 AM
I don't think it's any different from any other oil,all of it will leave carbon when burned.
I've seen saws that the exhaust port was almost carboned shut from stihl oil and a bad tune.
If there's no carbon on your piston crown after several gallons of gas your tune is rich.
CR500
8:06 AM
Western NY
Sent from my non internal combustion device.
I agree fully, however this is where finding what works comes into play, I use to run R50 at 32:1 and all other oils at this ratio, and thought it was dirty burning, however at 45:1 it is no more dirty than HP2 In my results
jmssaws
Banneded
7:06 AM
I think 32:1 is to much with any oil but for certain klotz and that's why it's called a dirty oil.
Ron660
7:06 AM
NW Louisiana
A clean piston is tuned too rich or the oil isn't properly combusting
I disagree. All my saws cleanup in the cut and my internals are a lot cleaner than Klotz with plenty of lube. If my saw is still 4-stroking under load it's to rich. Try Klotz Benol rich....it'll still be full of deposits.
CR500
8:06 AM
Western NY
Yamalube and HP2 always striked me as 32:1 oils, K2 I liked at 32:1, Bel Ray while tunning was different was alright at 32:1, Motul I ran at 32:1 but feel like I would like it at 50:1, Mobil 1 I plan on running at 32:1. Ipone 32:1 to start out.
Nothing wrong with reducing oil ratio if everything looks excessive and you feel safe doing so. This is where time and experimenting happens.
KenJax Tree
¯\_(ツ)_/¯
8:06 AM
Over there
Just because the saw is cleaning up doesn't mean the oil is combusting, it just means it's tuned right. Everything is clean because its not burning.
8:06 AM
800 when burnt will make a goo on the piston top.
Ron660
7:06 AM
NW Louisiana
I recently worked on an 034 that was tuned extremely rich. The piston and exhaust port looked horrible. My tach showed it a little over 12000. Very rich but full of crud!
8:06 AM
You told me 800 was the cleanest you've used just like Keith. Lubed almost as good as R-50 in the lower end but was super clean.
It still makes carbon. They all do some when they burn. I asked a guy I sold a saw to if there was carbon. He said exhaust port and piston top both. It was ran on 800 and milled 2 gallons worth in one day that I remember.
jake wells
no longer here
7:06 AM
ky
little smoke a little smell but it was only 2 bucks kick me in the nads if ya want to everything lived burning supertech this can't be to bad.
im mixing at 50:1 and im back to regular ethanol gas since they stopped selling ethanol free here.
8:06 AM
It is cleaner than super or 927 in a firewood saw. Cleanest is my lowest priority for picking oil. Fastest and happiest saw are top.
