Keith Gandy
Maxima K2 40:1 87 Pump Gas
- 12:31 PM
- Dec 30, 2015
- Provencal, Louisiana
1st. But what about both?
Ya the Mobil one was brown like that on the piston, exhaust, plug tooThank you Keith. That Mobil 1 looked like it is brownish.
The 2nd pic with RA oil, almost looked like a clear sheen on the piston.
I used that canam (or whatever it's called) stuff they had. It was so thick when it got cold. I could of cut it with a scissors.I figured. It's some brand I've never heard of. I'll get the name when I get home.
At 35°, it leaves strings in excess of 5' long when you're done pouring. Thins out in a few minutes of run time
Sounds like the same stuff. I didn't thin it yet, but 50/50 With fuel oil probably wouldn't hurtI used that canam (or whatever it's called) stuff they had. It was so thick when it got cold. I could of cut it with a scissors.
Had to thin it out some first.
I normally start at 3:1, a guy can always add more fuel oil.Sounds like the same stuff. I didn't thin it yet, but 50/50 With fuel oil probably wouldn't hurt
What would happen if you brought it up to 40:1?
No truer words have ever been spokenI don't know. I will repeat something that @tree monkey Scott has told me a few times.
He runs 32:1 because of the bearings. Those are what need the most oil.
