5:36 PM
Thank you Keith. That Mobil 1 looked like it is brownish.
The 2nd pic with RA oil, almost looked like a clear sheen on the piston.
Sty57
4:36 PM
Land of Cheese & Beer
I figured. It's some brand I've never heard of. I'll get the name when I get home.
At 35°, it leaves strings in excess of 5' long when you're done pouring. Thins out in a few minutes of run time
I used that canam (or whatever it's called) stuff they had. It was so thick when it got cold. I could of cut it with a scissors.
Had to thin it out some first.
5:36 PM
Sounds like the same stuff. I didn't thin it yet, but 50/50 With fuel oil probably wouldn't hurt
Redbull661
661 hoarder (BlueBallz)
4:36 PM
MN
Ran Schaeffer 9000 full synthetic on a new 661. 32:1 for 12 tanks running 36"-41" .404
This is NOT the tcw3 7000 semi syn.
Redbull661
4:36 PM
MN
What would happen if you brought it up to 40:1?
I don't know. I will repeat something that @tree monkey Scott has told me a few times.
He doesn't run 32:1 so much for the film of oil between the piston and jug. He says you really don't need that much. He runs 32:1 because of the bearings. Those are what need the most oil.
porsche965
5:36 PM
N.E. Ohio
I do know that running more lubrication to a bearing than what is needed raises the temperature of a bearing. Does this matter in a chainsaw? Don't know. This from the research department of Timken Bearings, Canton, Ohio. Just curious. You have a great track record of successes I sure won't dismiss.
porsche965
5:36 PM
N.E. Ohio
We should take a poll on bearing failures documented due to lack of oil and the ratio of oil the bearings were run at. It would support your thesis.
Is this why Husqvarna is beefing up their bottom end of the new 572xp so they can still comply with the EPA @ 50:1 without further failures?
