2:42 PM
Someone suggested an APP a while back. I downloaded it and use it now. It is pretty cool.
It is called Fuel/Oil Mix Calculator.
And yes, 2.56 oz of oil in .8 gallons of gas should give you 40:1. [emoji106]
1:42 PM
Ya iam learnad something new!
Redbull661
661 hoarder (BlueBallz)
1:42 PM
MN
kingOFgEEEks
2:42 PM
Tioga County, PA
Apps? That sounds like you are using math and stuff. I use math at work, I'm sure as hell not bringing work home with me...
Pour oil up to the line for 1 gallon at 32:1. Pour some gas in to dilute and shake it up, then pour back in the can. Shake it like a Polaroid picture. Go cut things.
GCJenks204
"Special Buns"
1:42 PM
Winnipeg, MB
Stupid question but say I want to make 40:1 with a 2.6 oz I would need to mix with .8 gallons at the pump.
fwiw I just google "oz to gal "
so take 2.6 x the ratio you want to run. 2.6x 40 = 104 oz now convert to gal. = .8125gal so you put in .813 gal of gas.
https://www.google.com/search?q=gal+to+oz&ie=utf-8&oe=utf-8#q=oz+to+gal
You poor saps. If your country had half a brain you would have gone Metric when Carter wanted you too.
4litre fuel = 4000ml + 100ml oil = 40 to 1...
tp2177
2:42 PM
AL
We don't need no metric around here! Even though everything in my field (medical) is metric, so I have to know both.
Edit: also if metric is so wonderful why do foreign sports car/super/hyper car still go by the 0-60mph times?
GCJenks204
"Special Buns"
1:42 PM
Winnipeg, MB
Because those silly puckers in England seem to use both. Litres for fuel and MPH for highway speed. That's a true WTF!!!
1:42 PM
No they need ton make 3.2oz bottles for 40:1 instead of this 2.6 50:1 garbage and the pumps could read oz too damit.
bikemike
1:42 PM
Cottage grove mn
The liter and kilometer system is stupid just bigger numbers to make you feel like your going faster when you se 120km.
Man this Lil euro truck is a beast. I burnt 23.5 liters to get to work.
2:42 PM
What is 927 Mike???
I know it is 2 stroke oil, but who makes it?
