jake wells
no longer here
12:48 AM
ky
After tearing down a 460 ran on Ultra and seeing a lot of carbon build up, y'all might have convinced me to try the KL-200.
Dang, sucked into a oil thread...
welcome to the dark side, bad tuning and cheap gas will cause that.
bwalker
1:48 AM
Montana
Spectrum Oil Co was bought out by Phillips 66 in 2014. http://investor.phillips66.com/inve...pecialty-Lubricants-Manufacturer/default.aspx
Here is the MSDS database of all products which they make:
http://w3apps.phillips66.com/NetMSDS/results.aspx?LanguageFilter=**&MSDSTypeFilter=USDS&SearchValue=%
The current formulation of Husqvarna XP oil shows <10% Polymerized fatty acid ester. The old formula did not have any ester in it.
http://w3apps.phillips66.com/NetMSDS/ViewPDF.aspx?fileName=829482&Language=EN&IssueDate=2/13/2014&SubFormat=USDS
Red Armor (Shindaiwa and Echo versions) is still showing no ester in the formula according to Phillips 66.
http://w3apps.phillips66.com/NetMSDS/ViewPDF.aspx?fileName=829447&Language=EN&IssueDate=12/4/2013&SubFormat=USDS
http://w3apps.phillips66.com/NetMSDS/ViewPDF.aspx?fileName=829626&Language=EN&IssueDate=12/4/2013&SubFormat=USDS
Maruyama Blue Ultra Shield is the same formulation as Red Armor.
http://w3apps.phillips66.com/NetMSDS/ViewPDF.aspx?fileName=829528&Language=EN&IssueDate=12/4/2013&SubFormat=USDS
Dolmar High Performance oil has 10-30% Ester .
http://w3apps.phillips66.com/NetMSDS/ViewPDF.aspx?fileName=829439&Language=EN&IssueDate=12/9/2013&SubFormat=USDS
For you Aussies the Jakmax Syn looks good. Same as Makita and Poulan Pro Synthetic. 10-30% ester.
http://w3apps.phillips66.com/NetMSDS/ViewPDF.aspx?fileName=829493&Language=EN&IssueDate=12/9/2013&SubFormat=USDS
Makita Synthetic:
http://w3apps.phillips66.com/NetMSDS/ViewPDF.aspx?fileName=829524&Language=EN&IssueDate=12/9/2013&SubFormat=USDS
Poulan Pro syn:
http://w3apps.phillips66.com/NetMSDS/ViewPDF.aspx?fileName=829579&Language=EN&IssueDate=3/18/2015&SubFormat=USDS
Honda HP2:
http://w3apps.phillips66.com/NetMSDS/ViewPDF.aspx?fileName=817713&Language=EN&IssueDate=4/16/2015&SubFormat=USDS
Woodlandpro formula no longer contains ester as of 2-21-17:
http://w3apps.phillips66.com/NetMSDS/ViewPDF.aspx?fileName=829708&Language=EN&IssueDate=2/21/2017&SubFormat=USDS
Yamalube 2R:
http://w3apps.phillips66.com/NetMSDS/ViewPDF.aspx?fileName=829733&Language=EN&IssueDate=8/24/2016&SubFormat=USDS
Phillips has made some very good two cycle oils over the years.
PissRev
1:48 AM
Ga
i pulled the SDS on the redmax oil i bought maybe someone can tell me if it looks decent.
http://www.redmax.com/ddoc/RMXE/RMXE2015_NAen/RMXE2015_NAen_MSDS 20 STROKE OIL_929615.pdf
The first ingredient is a hydrocracked oil which may or may not be processed enough to call it a synthetic group III oil. The second ingredient is deodorized kerosene probably included to help the oil mix with the gasoline more readily. The other ingredients are fuel stabilizers. What you don't see in here is that around 40% of the oil is not accounted for in this SDS. It could be any base oil component which is not hazardous. Redmax oil is FD rated and I'd use it without hesitation.
jake wells
no longer here
12:48 AM
ky
I got four 1 gallon jugs of it so i plan to use it.
2000ssm6
1:48 AM
NC
Just bought a quart of KL200, what bottles are yall using to measure mix with? None of my HP Ultra bottles have the clear window on the side. The next time I go to Lowes, will look at the cheap bottles.
PissRev
1:48 AM
Ga
Still running on red armor here. I'm curious about this VP oil. So its red? And does it smell pleasant?
I never notice a smell using ra. But ultra is nauseating
VP is red and it has a very plesant scent even at 32:1. It's one of the few oils that my girlfriend doesnt complain about.
1:48 AM
I just use the sight window on the qt jug. 4oz per gallon is pretty easy. 32-1
