X 66 stang347 X
- 11:34 AM
- Sep 23, 2016
- Georgia
I can't remember but I don't think it was very quiet. if you look for that
Theres a good candidate for a muff mod. Over scavenging
U know someone had punched a hole in the muffler with about a 3/8" drillbit! That thing had serious buildup
I've used this. It was quiet and lasted for cutting grass![]()
Suprisingly the crown and chamber was decent@Keith Gandy
I could be wrong. Idk. Just guessing.
Seems like a lot of burned carbon getting blown all the way down into the case.
i use the .105 in everything.Tried the .118?
Viscosity is a measure of how easy an oil combusts. As viscosity goes up so does its ability to resist combustion.I think some of the mixed results we see with the high temp oils are just due to how they are being run. If not run hard you get build up etc.
That is one of the reasons I like HP2 - it's a mid temp but high viscosity. So in my mind that would mean it would burn well when saw is idling and the high viscosity (18 vs something like ultra 8) will protect at max output.
that said my jury is still out until I do the oil test. I don't think it'll decide a ratio to use. But I think there will be a few oils which prevail as fastest and show a trend/pattern giving us an idea of an ideal operating temp.
Ben what would u consider prime range on the viscosity for saws, (firewood), trimmers, blowers, ope in general? How about milling?Viscosity is a measure of how easy an oil combusts. As viscosity goes up so does its ability to resist combustion.
The flaw here is using flash point as a measure of the temperature the base oil combusts. This isn't what flash point is.
With a high viscosity oil wouldnt using a higher ratio or less oil aid combustion?Viscosity is a measure of how easy an oil combusts. As viscosity goes up so does its ability to resist combustion.
https://en.wikipedia.org/wiki/Viscosity
The viscosity of a fluid is a measure of its resistance to gradual deformation by shear stress or tensile stress.[1] For liquids, it corresponds to the informal concept of "thickness"; for example, honey has a much higher viscosity than water.[2]
Viscosity is a property of the fluid which opposes the relative motion between the two surfaces of the fluid in a fluid that are moving at different velocities. When the fluid is forced through a tube, the particles which compose the fluid generally move more quickly near the tube's axis and more slowly near its walls; therefore some stress (such as a pressure difference between the two ends of the tube) is needed to overcome the friction between particle layers to keep the fluid moving. For a given velocity pattern, the stress required is proportional to the fluid's viscosity.
A fluid that has no resistance to shear stress is known as an ideal or inviscid fluid. Zero viscosity is observed only at very low temperatures in superfluids. Otherwise, all fluids have positive viscosity, and are technically said to be viscous or viscid. In common parlance, however, a liquid is said to be viscous if its viscosity is substantially greater than that of water, and may be described as mobile if the viscosity is noticeably less than water. A fluid with a relatively high viscosity, such as pitch, may appear to be a solid.
Hmm so my price sounds pretty good compared to yours?I just paid $20.87 for a 6 of the 6.4 oz.
Just checked with my echo dealer on red armor pricing. I bought a 13 oz bottle a while ago but they don't stock that now. All bottles labeled Shindiawa.
6.4oz $2.95 or $15.95 x6
2.6oz $1.99 or $11.25 x6
How does that compare?
38.4oz for 15 is really goodJust checked with my echo dealer on red armor pricing. I bought a 13 oz bottle a while ago but they don't stock that now. All bottles labeled Shindiawa.
