Adirondackstihl
4:38 AM
Upstate NY
I'm mixing with VP SEF.....
But a few months ago I got a 5gal pail of C9 at a crazy cheap price.
It's all pricey *s-word.....but to me it's worth not rebuilding carbs and replacing fuel lines.
Heck.....5gal last me almost a full yr
Moparmyway
Its just a saw
4:38 AM
In a meeting
I am now into my 7th 5 gallon pail for 2015 .......... might need to open #8 this weekend,
but that will havta count for 2016 as #1 I guess
Moparmyway
Its just a saw
4:38 AM
In a meeting
I have super and that picture of the piston of a 7900 was ran with it. I think the deposits are more a product of the gas and not the oil as much as we thought.
Although I will say that the Echo FD certified synthetic left more deposits than the mix I run now ............... all with VP
4:38 AM
I've not ran enough VP through one saw to see if it's the fuel. I've been lucky to get a tank a month lately. I did run Matt's 7900 out last night. I cut cookies for right at a whole tank. Its got VP now and the piston top wasn't real dirty. He's been running Lucas from what I remember.
NorthcentralYooper
4:38 AM
Upper michigan
They mostly run too rich. Especially ported. Had a 576 that would 4 stroke with a 20" unless you run an 8 pin and pushed hard. The 550 was finicky on fuel and really needed 40:1 with a thinner oil than 800 or Belray for sure.
I was told the 576 has the older technology Autotune , what makes you think you needed richer mixture or different viscosity? On the 550 Just curious
jake wells
no longer here
3:38 AM
ky
here is what 5 yrs of supertech air cooled 2t at 40:1 looks like in my old mans trimmer
all he runs is that oil mixed with walmart/murphy gasoline.
4:38 AM
I was told the 576 has the older technology Autotune , what makes you think you needed richer mixture or different viscosity? Just curious
The 550 ran better with a thinner oil like k2 over 800. The 576 ran pig rich with every oil with a short bar.
Moparmyway
Its just a saw
4:38 AM
In a meeting
I ran 5 or 6 tanks through a ported 33cc saw ................ took forever to do it too
But - I started with a clean piston and ended up with less than a fingernail of wash for the transferr area on the piston top with the Echo.
I never cleaned it up, but now it looks about the same as the 661 with 20% wash over each of the transferrs now. All I did was switch oils and run the same VP fuel
I think they both influence the deposits, maybe more the fuel than the oil
jake wells
no longer here
3:38 AM
ky
echo red armor burns cleaner than regular echo oil. my echo trimmer runs the best on xp oil not sure why.
NorthcentralYooper
4:38 AM
Upper michigan
I'm picking up a 5 gal pail of C9 today Should last me close to a year , I cut 16 face cord a yr then random brushing in between. I'm running dominator oil
cgraham1
1:38 AM
Nor Cal
I like H1/R exhaust fumes. They smelly yummy. The raw mix gas fumes burn the chit outta my eyes though.
jake wells
no longer here
3:38 AM
ky
belray mineral 2t is 8$ liter and good stuff.
