12:21 PM
You running the Benol at 40:1 still Jason?
12:21 PM
Wow. OK
What do you have to do to the tune to make it work? Without all the spooge.
12:21 PM
I guess spooge is a far too fat tune? Should I Lean it up some?
CoreyB
11:21 AM
South east iowa
Ive never had any oil spooge.
Spooge is a tune problem not a oil one.
When I ran Saber I was tuned on the rev limiter hard. Like bounced past the limiter and hit 14,500 on a 13,500 saw. And was still getting some build up at the exhaust. I was scared to go any leaner.
jmssaws
Banneded
11:21 AM
Tuning one faster doesn't necessarily mean that it's not fat.
The low is usually the problem
KenJax Tree
¯\_(ツ)_/¯
12:21 PM
Over there
Its called 'Bynorm' and is made by Stens. It is an FD rated oil "suitable for all air-cooled two-stroke power equipment" - and by Australian standards it is fairly cheap, $17 per litre. I run it at the 'metric' 33-1. (that's 150ml oil to 5 litres of petrol)
Ahhh you're in AUS. We don't have that here
jake wells
no longer here
11:21 AM
ky
i converted my mix for you
236.5 ml to 7.5 liters
Terry Syd
4:21 AM
Comboyne, NSW Australia
So you run a mix of 31.71247 to 1. I'm impressed with your precision.
The 150ml is easy to measure for a 5 litre jug - thus I called it a 'metric' measure. If I was mixing ounces and gallons I'd probably be using 32 to 1.
