KenJax Tree
¯\_(ツ)_/¯
5:57 PM
Over there
Exactlty! Hence reasoning why quality is always a sought out item and not easy to obtain
However if the quality has gone down and it is now A blend like all the other oils then it's simply is not worth what they charge for it.
99% of the people going into buying oil don't even care and just buy the cheap one and will never know the difference
Keith Gandy
Maxima K2 40:1 87 Pump Gas
4:57 PM
Provencal, Louisiana
We r totally assuming that its not as good as the old version if their is a NE and OE
Nitehawk55
5:57 PM
Ontario
Well if it is changing I'll grab a case of 12-1qt bottles while I can or I guess you could add something like a bit of Motul 800 if you want some esters in the mix .
Terry Syd
9:57 AM
Comboyne, NSW Australia
I tried Klotz when it first came out (1974 I think). At that time it was a racing oil without a lot of detergents - it gummed up the rings very quickly - about as bad as castor oil. The next generation of Klotz had more detergents and would keep the rings free. I was racing in the desert with high heat and load and thought I might need the extra protection.
I ran the Klotz for about a year and then went back to Pennzoil - never had a problem with the Pennzoil, but the bike did have better throttle response with the mineral oil (I expect the mineral blends are a lot better since the 1970s). The Pennzoil also gave a bit more range on a tank of gas
I run a good CD rated mineral oil now in these low powered OPEs.
CR500
5:57 PM
Western NY
You still running Benol J?
Don't tell me you found something wrong with it lol
Sent from my non internal combustion device.
KenJax Tree
¯\_(ツ)_/¯
5:57 PM
Over there
What mineral oil are you using?
