bwalker
1:55 AM
Montana
One of the reasons I use kl200 is that testimony u gave me. I disagree with Ben in that u have to wear a saw out to tell what an oil is doing. Sometimes a few tanks will indicate what that oil will produce in extended lengths. Heck I partially stuck a ring with Supertechniplate in less than 3 tanks in a 550xp
You might get a very rough idea, but a few tanks doesn't constitute a track record.
Keith Gandy
Maxima K2 40:1 87 Pump Gas
12:55 AM
Provencal, Louisiana
From the images of crankshafts and pistons smothered in oil that have been posted ,seems like a lot of unburnt fuel going to waste not creating energy ,these engines run better not drowning in the stuff .The cleanliness is more from wash than a clean oil i bet .Excess oil should not be pooled up in the bottom of the crankcase .
All depends on the rpm the saw was shut down at
bwalker
1:55 AM
Montana
So Original would be your pick out of the Klotz lineup?
R50 at 32:1 still is excessive IMO lol.
Will mix up some original at 32:1 this weekend. Only ran it at 50:1 and it looked a tich dry....however Ben, residual is a heavily influenced factor from many things.
Ran Benol at 32:1 with the leaner coil on the 661 while running the maxflow and everything was decent looking. Castor does burn dirty I know but it is arguable that it does lubricate better than some synthetics.
There is a trade off with Benol and I understand this, I run synthetics this time of year due to weather lol
Will run original at 32:1 year round if I really like it.
Still will not be afraid of2r at 32:1 lol. K2 or Super M at that ratio have not cooked a saw yet either.
I broke in a 562 on2R and Super M. Saw never missed a beat or had any abnormal wear.
Sent from my non internal combustion device.
Castor does exactly one thing better than other base oils in a two stroke. Before it breaks down from heat it turns into a sprt of grease. It can give you a brief window where it prevents a seizure, although it's definantly still possible to seize with it. That's it. It pretty much sucks st everything else.
And with a chainsaw you never get into a situation that stresses the lube enough to use castor.
1:55 AM
OK. Cool. Lots of things going on in this thread. Just wanted to clarify. Thanks.
jakethesnake
I Am The Snake
1:55 AM
Here & Now
If my stuff sits I pour it. Though they always have fired on what's in the carb I use anything my cheap ass can get ahold of with no Ill affects so far
1:55 AM
I see hybrid 2 stroke mixes coming in the future here.
A base 50:1 mix of good old fashioned 2 stroke oil with some more exotic 2 stroke oils as an additive to get to 40:1. Lol
Let the concoctions begin.
1:55 AM
Motul 800 has a 60:1 mix recommendation?
