jake wells
no longer here
12:06 PM
ky
nope it they leave the injector pumps alone they wouldn't have to spend 1500$ on a overhaul. we got bone stock kubota diesels with 12,000 hrs on them still running strong.
Keith Gandy
Maxima K2 40:1 87 Pump Gas
12:06 PM
Provencal, Louisiana
241c with 87 efree both mixed at 32to1. The first 2 pics r hp2 and the last 2 r Yamaha R2. Not only did the R2 burn the mix off in the cylinder better and changed the wash pattern but r2 also left more residual oil in the bottomendScreenshot_2016-01-07-00-25-45.png 20160106_110348.jpg 20160113_081912.jpg 20160113_085352.jpg
Ron660
12:06 PM
NW Louisiana
Ron660
12:06 PM
NW Louisiana
bwalker
1:06 PM
Montana
Is it the same sound as in a vehicle?
241c with 87 efree both mixed at 32to1. The first 2 pics r hp2 and the last 2 r Yamaha R2. Not only did the R2 burn the mix off in the cylinder better and changed the wash pattern but r2 also left more residual oil in the bottomendView attachment 3756 View attachment 3752 View attachment 3754 View attachment 3755
Residual oil is a product of ratio and how the engine was operated when it was shut down.
I assure you I could make any engine with any oil soak the bottom end in oil.
And given the above it's another pro to running something like 32:1 vs 50:1. More protection from corrosion.
Keith Gandy
12:06 PM
Both set of pics were of wot and shut off several times. Alil more idling on the set of r2 pics
Keith Gandy
12:06 PM
The first pic indicates a rich fuel to air ratio or limited run time before rear down.
Both set of pics Ben were of a mtronics 241c with 87 e free both cutting cookies at wot and shut off at wot. No 2 ways around it the 2r burns less rich in the topend and the bottomend has more residual
Keith Gandy
12:06 PM
I see no need at all to burn thoso upper end high viscosity oils in my 241c . The 2r looked better all around top and bottom
