bwalker
6:30 AM
Montana
Ever mix race with the pump gas for the bikes Ben ?
Yea, and the same with AV gas. It's kinda of a circle jerk though as you never get real consistent results vs pure race gas.
junkman
Crush it
3:30 AM
pacific northwest
Was told not to run av gas in the bikes because it was designed for higher altitude ?
6:30 AM
Well I used all but 4 oz of the fuel mixed with HP2 around 20:1. Rpm out of the wood dropped when warmed up about 400. I reset the saw to 12.8k for the first cut. I checked right after a cut and it was the same. Temperature had dropped in the mid 30s with a nice breeze. I timed the first cut and it was 6 minutes 35 seconds with the time to walk to the log and start and time to go back and cut the timer off. The phone was on the truck 8' away so it was maybe 10 seconds total. Power was about the same as yesterday by the time of the cut. The top of the piston was wet on most of it. I only idled it maybe a minute since it was cool and only one cut.
bwalker
6:30 AM
Montana
Doesn't hurt anything, just has really crappy throttle response and seems to impact hp as well.
Keith Gandy
Maxima K2 40:1 87 Pump Gas
5:30 AM
Provencal, Louisiana
View attachment 3605 View attachment 3607
So Mike u still prefer the super techniplate or kl200 for milling?
Keith Gandy
5:30 AM
What's the compression ratio?...
Heck Ben do u really think anybody on here is gonna measure trapped and static volumes??? Lol!! The way on here is go for topend compression and pull a ratio out of the air and assume they need more octane
jake wells
no longer here
5:30 AM
ky
a little OT i tried some belray H1R in a 2 stroke pusher over the summer and it seemed to run a little better than others i have mixed at 32:1
the compression ratio on the pusher is 5.5:1. i also noticed the muffler had oil puddled in it as before it didn't.
Ron660
5:30 AM
NW Louisiana
Most 110 fuels I have seen have distillation curves totaly wrong for a two cycle. So it makes sense 110 would perform poorly. AV gas is in the same boat IME.
Only way to know is to conduct timed cuts with YOUR saw. It's that simple. You can theorize all you want. Test your saw then you'll know. I deal in facts not theories.
Ron660
5:30 AM
NW Louisiana
I'm not disputing your statement I'm just surprised 110 was faster in my saw. I'll test again to confirm my findings. I forgot what racing you requested for my saw?
