Tomos770
1:22 PM
Slovenija
Once I had an opportunity to be working with Makita MM4 trimmer.....that was just before they anounced that they will bail out of gasoline program....around year 22/23....
I was impressed....as Lilspenny is describing....superb low rpm torque.....I was able to cut small trees/branches with ease with reinforced 2.4mm string
But that was more like Hondas gx25/gx50 engine then 4-mix....
rogue60
10:22 PM
AU
Not in a chainsaw and not in a two cycle. What works in your 4 cycle blower is irrelevant to a chainsaw. The design of the 4mix is garbage and Stihl used a special oil ( Ultra) to band aide the issue.
The best and only way to test two stroke oils and establish whether or not it's any good to run in a chainsaw is to run it in a 20 doller weed eater it's called internet's science! the end...👌
lilspenny
6:22 AM
That paper was written 33 years ago. Since then almost all FD oils are PIB blends. I think they figured out how much and what weight PIB's to use a long time ago.
Also of note is that Yamalube 2R is a PIB blend and has been for 40 years or so. It also has a track record of results that very other oils can match. Honda even ran the stuff back in the day.
10-4 good info. Thanks.
bwalker
7:22 AM
Montana
That test was ridiculous for variety of ressons...
lilspenny
6:22 AM
It seemed to me that Richard Flagg had some concern with regard to the tackiness of Red Armor. Of course a good track record, which Red Armor has, will erase those concerns... At least they would from my mind. I wonder if Richard read that Yamaha paper and was sending out a feeler based on that. Thanks BW.... Oh, I have never run 2R in a 4-mix so I was thinking of trying it at 40:1, taking the exhaust temp, checking rpm, and going from there. Your thoughts on 2R in a 4-mix? Not sure about today's 2r composition and valve deposits, valvetrain heat, wear, etc.. ..
lilspenny
6:22 AM
I m so happy that i stayed at 2 stroke. No4 mix for me.
To me the biggest drawback is on blowers due to the cam being so difficult to access. Requires too much labor. Stihl has cost themselves a lot of money by not selling more 2 stroke models.
lilspenny
6:22 AM
Surprised stihl even makes blowers any longer. Seems like 9 out of 10 landscape crews run redmax and echo. They’ve had that market cornered for years
I think a lot depends on the local dealer. If I were to buy from a local dealer here in Athens, AL it would be Echo or Shindaiwa because of the excellent dealers who stock parts. Stihl parts will most likely take a week. Waiting a week just doesn't cut it.
bwalker
7:22 AM
Montana
Remax and Echo make much better blowers and trimmers.
bwalker
7:22 AM
Montana
Stop watching youtube and expecting you will get any useful information.
Richard Flagg is full of crap in this regard.
I would stick to 50:1 in your 4mix...for like the third time. A 4 stroke runs much cooler piston temps than a two stroke. Blowers and trimmers are also under much less load than a chainsaw.
In addition I would lean the carb out on your 4mix to the point it starts to lose power or has running issues. It will run cleaner like this and unlike a 2 stroke will not seize.
MtnHaul
4:22 AM
West Coast Mtns.
Might be a regional thing. Where I live it seems that at least 90% of the back pack blowers I see are Stihl. Zero Redmax and very little Echo.
SawAddictedFarmer
6:22 AM
We do have a excessive amount of Stihl dealer's though. Not many echo dealer's around and I don't even know where you would go to buy redmax
MtnHaul
4:22 AM
West Coast Mtns.
Echo only available at local Home Depot. Many Stihl dealers but closest Husqvarna dealer is a long 40 miles away. RedMax ain't a thing out here.
EFSM
6:22 AM
Extreme southern IL
It is. Go to coastal California and it’s different there. Echo started marketing the first backpack leaf blower there over 50 years ago. It was a slightly modified gas powered duster, which is what the Japanese farmers used in their fields after we knocked their industry flat in WW2.
MtnHaul
4:22 AM
West Coast Mtns.
Since I live near coastal CA I can confirm that statement. I am bit surprised at the near total market saturation of Stihl products. Whenever I pass a tree or landscape crew I always try and sneak a peek at what brand equipment they're running and it's almost always Stihl or if it's a battery tool I see some EGO equipment. I have nothing against Husqvarna and might've bought some of their stuff but nobody in the county stocks it--even the one listed Husky dealer has to order anything you might want.
edisto
7:22 AM
SC
You would be suprised..
Especially homeowner saws. I hear them now and again in our area, and heard a bunch after the hurricane, but I've never heard one "2-stroking" in the cut.
16TAF
7:22 AM
VA
Any opinions on this Husqvarna oil? I found a bunch in my grandpa’s shed. He hasn’t cut in 20 years so it’s at least from 2005ish.
