smokey7
3:13 PM
Detroit
Soooooo where are we at as far as oil goes? Any stand outs that make the top 5 easily? Is 32-40:2 still acceptable with a good synthetic? I still think i wanna look up some premium dino oil fir that oldtime smell i grew up on. I can still smell that smell im my memory of the snomobiles first start up in the garage....... god i miss those years of my life.
stihl saws
You can always justify another saw.
3:13 PM
Virginia
I think most of us would agree, it's all about the application. Then we'll fight it out over the brands and types.
Keith Gandy
Maxima K2 40:1 87 Pump Gas
2:13 PM
Provencal, Louisiana
Hey guys, I was thinking about these take downs im doing. Thinking the results would be different depending on the load on the saw right?
In other words
ported saw running 32:1 xyz oil with a 41" .404
vs
stock saw running 32:1 xyz oil with 24" 3/8
things would probably be dryer etc etc on the ported saw.
So thinking I should just use a ported saw and load it up the same way every time (long bar .404 full comp) and run every oil at 32:1 and then do my take downs. (also I have a ton of wood in the same pile I could buck up...so the wood and cutting would be the same as well)
thoughts?
Probably as consistent as u will be able to control?
odin
100% noodle arms
2:13 PM
ks
In other words
vs
thoughts?
This is EXACTLY what I was thinking when I asked you about your B&C setup a day or so ago. I would think running a short bar with an "easy" load is gonna burn a lot different than the long bar buried dogs-deep.
But what the hell do I know, I'm just the helper...
... Just out of curiosity, Redbull, what B&C setup do you test with?...
CoreyB
2:13 PM
South east iowa
I agree load and application would be as much of a contributing factor as any thing else. Like my experience with red armor almost no smell and very clean in the saws at 42.5 :1 but the weed eater has some damp on the exhaust and the smell is definitely noticeable.
The Dolmar synthetic seems more even across application and load.
bwalker
3:13 PM
Montana
In other words
vs
thoughts?
Load has a huge influence.
Roost426
12:13 PM
WA
I was seeing it mentioned that the Super Tech Fully Synthetic in the silver bottle was made by citgo. The bottles of it I have been using up here in washington have a WPP on the bottom which is Warren Petroleum. I would believe it is most likely this or very close to it.
http://www.mag1.com/ProductDetails.aspx?id=4f877bb4-a1e6-4e3c-8ccd-a31d1fad59f5
This oil has been working just fine for me and the price is great.
junkman
Crush it
12:13 PM
pacific northwest
bwalker
3:13 PM
Montana
Damn Ben! Why does someone have to be stupid if they don't reason as you do? It must suck going through life thinking everyone else is stupid...
I didn't say anyone was stupid. I said running a mesh filter is stupid. IMO it is. Essentially your trading of filtration for a miniscule increase in performance. With most saws you will never know the differance performance wise
paragonbuilder
3:13 PM
Norwich, CT
You quoted Keith saying he uses mesh filters, and then said using mesh filters was stupid. It's not much of a stretch...
Instead of sharing that you feel "others choices" are stupid, why not share your experience as to why you feel this way. At least then we can learn something!
Your a smart man with valuable insight, but the way you treat others is exactly why some have left this site...
