bwalker
4:12 AM
Montana
Years ago, I was using Klotz oil. I mixed it in the red gallon jugs. I was fixing to top off a trimmer and when pouring I could not tell the gas was mixed. Looking in the red jug, I could not tell if the gas was mixed. Under the circumstances, I poured that gallon in a mower I had at the time. Mixed a new batch and proceeded on.
The mower had about a 4 gallon tank, so that gallon I poured in was mixed with more gas. Long story short, that mower for 5 or 6 tanks later still smelt like Klotz when using. To this day, I still wonder for such a diluted amount, how did it last so long? Thinking back on this, it may have been the super techniplate which has castor oil, I believe.
Funny you mention that. I ran out of gas in my Honda powered pressure washer last year so I filled the tank up with maybe a quart of Klotz Super Techniplate at 32:1. I ran that tank empty and then filled it with straight fuel. Used the it several more times then added Stabil to the tank and winterized it. Pulled it out this spring and I will be dammed if it didn't smell like Klotz for the entire tank of fuel as well as the next.
Nitehawk55
4:12 AM
Ontario
I run my 2 stroke mix in the snow blower and it's hardly noticable except on start up .
It's a Tecumseh 10'5 Snowking and I suspect the added lube to the valves is likely a good thing . This will be it's 12th winter coming up , I should do an oil change , use 0W30 for that .
3:12 AM
Southern illinois
You want to run one with a 2 piece head for a week if I can get it done? I want to see if it will hold up in a real world application. I won't have time to set up and mill for a day when I get it done til I find more suitable logs.
Sure thing! I was only joking but if you want me to put one to work i'm game
Red dye is the same color as off road diesel here ,not sure if i would want the same color mix as the diesel if i was not filling up the machines .
Diesel is transported in 100 gal tank, i never have any in jugs so it's all good... Valid point though
3:12 AM
Southern illinois
I like dolmar synthetic as well. To me it has a pleasent smell, much better than ultra. A few years back i was getting red dyed orange bottle stihl oil.... Had to look through the little clear strip on the side of the bottle to distinguish whether it was the normal or the red. I liked that stuff but if the dealer had 50 6 packs on the shelf you may have had to pick up half of them to find one with red. It was around the time ultra was released iirc
Fairways_and_Greens
1:12 AM
Bothell, WA
3:12 AM
Southern illinois
I do want to send one to someone who puts a good bit of fuel through one a week.
It will be taken care of. I don't beat my saws around. Definitely wouldn't someone else's. I did throw a 661 a few times recently though.... Lol. But it has been hot and a saw should start in less than a dozen cranks
Stihlbro
4:12 AM
Virginia
Where is that Klotz hanging out at ?
Stihlbro
4:12 AM
Virginia
That same oil here messed up several saws that was always run on the original orange bottle. It seemed as if it decarboned the piston and carbon streaked the cylinders.
3:12 AM
Southern illinois
That same oil here messed up several saws that was always run on the original orange bottle. It seemed as if it decarboned the piston and carbon streaked the cylinders.[/QUOTE
Zero issues with it here. I know the red colored stuff didn't last long. At the time my dealer had said he didn't know why they didn't make the ultra red dye instead of sending out orange bottle with red oil. If the red dye stihl oil was available here I would run it.
