Keith Gandy
Maxima K2 40:1 87 Pump Gas
12:24 AM
Provencal, Louisiana
Im seeing that alota folks r thinking that a perfectly clean piston , wet, and a cooler running 2t engine is right vs a piston with carbon, dry combustion area, with alil warmer engine? Whos right?
Keith Gandy
12:24 AM
No one is right ,personal preference thing .
But there is a right way for an engine to operate the way it was designed to operate. A 2t engine isnt designed to run perfectly clean and wet and produce the hp it was designed to? I agree its a choice but the right choice? I guess it depends on what one is looking for?
Keith Gandy
12:24 AM
You can tell when there is too much because the 2nd and 3rd cut in a row will get progressively slower. While the cooler (or better said proper temp) running saw will produce not only faster times but also those times will be consistent and not slow down. I've seen this time and time again in my various tests.
You can also tell when the saw is indeed too cool because the same thing happens on times but the saw also seems to struggle progressively the more cuts in a row you do. ...seen this happen when there is too much oil.
So I think heat can go both ways. Too much or Too little.
Sounds about right. Maybe theres a happy medium
bwalker
1:24 AM
Montana
A clean piston and wet exhaust is power left on the table. This is only questioned in the chainsaw world..
smokey7
1:24 AM
Detroit
To describe my pistons with no pics is a slug with no carbon at transfers. Thick carbon near exhaust and tan near intake. Most are ported.
T.Roller
1:24 AM
Southeast, TN
So I'm on my second gallon of mix of H1R. Not enough to really tell anything other than it has much more of a tolerable smell then ultra. Yalls thoughts?
smokey7
1:24 AM
Detroit
Here is a Stihl MS260 of mine ran on Motul 800. Yours about like this?View attachment 28932
Yes that's close just a little thicker carbon and a little drier. I probably tend to jet and tune a bit sharp. Actually really close to the edge on many things saws included. If I got a 125 I want all its got. My last motor that lost a rod bearing had probably .030+ of carbon on the top of the piston. Transfer wash was very noticeable and intake area was pretty open and clean with a hint of tan.
bwalker
1:24 AM
Montana
Took apart my 562xp tonight to do a base gasket delete. This saw has ran K2 at 32:1 since new and has been a flawless saw for me. I lost track of how many gallons of fuel I have ran through it, but I know I have cut 60 full cord or 3 log truck loads of fire wood with it, including one load that required nearly every round to be noodled in half in order to move them to the splitter. I ran mostly an 18" bar, but also a 24" full comp quit often.
Here is the head. Camera died so I will take/post the other pics tommorow.20160801_205656.jpg
Keith Gandy
12:24 AM
Here is the head. Camera died so I will take/post the other pics tommorow.View attachment 28967
Dang tease!!!:D
CTYank
Killer of Invasives
1:24 AM
CT Panhandle
One thing that's really important and hard to see is how the oil works for keeping the rings and their grooves free and clean. Who gives a rat's patoot about a wet piston crown? M'self, I like to see piston crown with a nice light coating of beige after a serious workout. Saws sure seem to like that, as do polesaw & brushcutters. (Stock engines, 50:1 full syn., 89 octane E-10)
Some experts say that extra oil in the mix has the effect of reducing the effective octane #. That can't be good. :ambulance: Extra POM definitely not good.
bwalker
1:24 AM
Montana
Clean ring grooves are absolutely important for long term wear. No doubt about it.
The experts you are quoting shouldn't make blanket statements. Some oils raise octane, some lower it, but to worry about that factor in a very low compression engine like OPE is a joke.
