CoreyB
- 4:09 PM
- Jan 26, 2016
- South east iowa
Humm they make great stuff!Yes. Its says on the MSDS
good list for sawsKl200, r2, hp2, K2, or Amsoil would be my picks so far
Ya. Doesnt combust well in a saw unless u mill with it@junkman and @Keith Gandy, have you tried Motul 800 yet? (Pretty sure Brian barfed at the red dye).
How long has ur plug been in ur saw with the amsoil? Can you snap a pic pleaseNever tried 800 milling the Amsoil is doing fine 40 to 1 so far so I have stuck with it.
Keep in mind his plug will look different as he is tuned rich for milling. Likely will have carbon on the outer edge of plug near the threads. I still believe it's very good oil.How long has ur plug been in ur saw with the amsoil? Can you snap a pic please
I think it sucks unless the saw is on a mill for hours at a time. Other than that it leaves a wet piston top from not burning. It will make some hard deposits after milling if it's ran hard enough to burn.@junkman and @Keith Gandy, have you tried Motul 800 yet? (Pretty sure Brian barfed at the red dye).
Only makes sense in a 2 stroke that a cooler running saw isnt gonna make more power . A 2 stroke needs the proper load and temp. Range for the oil to combust. If it isnt combusting it will end up wet, washing the piston, and making less power IMO. Extra oil in the topend thats not combusting is like pouring water on the fire. Like Mdavlee said 800t wont combust, burn, or make full power unless its a load and temp that milling produces. Just my opinionwell if schaeffers can clean this thing up. I'll check again and see if there is still a difference. That said I got this saw from Dave in BC. It's 66F there right now and 78F here.
661 #3 had the slowest times of the day in all 4 logs. So I guess not.
