- 12:51 PM
- Dec 28, 2015
- TN
Test this.
Read his last two sentences again for all those who do not understand why a hated fuel can make more power. I have never been able to pound that into the heads of half the racers I've met. They just can not grasp it. They will insist that gas will make more power in the same displacement. Plus they miss all the other added benefits.
Try this sick mix for added power. Be warned your conventional (gas) fuel system will hate you if you leave it soak.
A gallon of E-85 mixed with walmart supertec 50-1 then add more (oil, your choice) I chose synthetic to get to 35-1, jump up the carb about a third in size. More ignition timing helps. Promotes smiles every time
Some go boom. Your results may vary lol
Is this the right oil and ratio?[/QUOTE]
I would use klotz original or super techniplate to mix with that.
