full chizel
¯\_(ツ)_/¯
- 6:06 AM
- Sep 12, 2019
- USofA
Does this have a dye in it? Anyhow, it looks like good oil. I bought some Liqui Moly 2T oil once and it had no dye like the old Mobil1 MX2T.This is my favoritView attachment 375740
The quoted viscosity would have to be correct or they would fall foul of even the USA's pathetic consumer protection lawsThe largest problem with 2 stroke oil, is published viscosity. Sure you can send a sample of each oil to a lab and PAY to obtain this info. However every other oil API certifies has to have the donut rating and viscosity on the label.
Nothing wrong with 2R. Dominator is better for tuning to my ear though.@Mastermind …you used to run 2R correct? Any negatives? Or just like what you use better? I know I know…it’s just oil.
We know through trial and error, the higher viscosity oils tend to do better at protecting bottom end bearings. Amsoil Dominator is the exception to that general rule. Motul 2T 800 is a 18.9 @100C Dominator is a 7 @ 100C. These are the only 2 I could find, and someone paid to have the Motul analyzed. I think in the U.S. 2T is the grade and it gives you a ton of wiggle room. Cohesion is directly related to the oils viscosity, adhesion has as much to do with the surface finish being lubricated as it does the oil itself.The quoted viscosity would have to be correct or they would fall foul of even the USA's pathetic consumer protection laws
However it would be meaningless because the oil is in suspension with the fuel when you use it
Molecule size would be much more useful but even harder to understand because that changes according to how many fuel molecules the oil latches onto when dispersed into the fuel
Viscosity is a measure of the VISCIOUS friction of the bulk oil.
Adheasion & coheasion indexes again would give a better indication of the oils service qualities when in suspension / dilution .
Been using Motul 800 2T for over a decade now , no complaints.We know through trial and error, the higher viscosity oils tend to do better at protecting bottom end bearings. Amsoil Dominator is the exception to that general rule. Motul 2T 800 is a 18.9 @100C Dominator is a 7 @ 100C. These are the only 2 I could find, and someone paid to have the Motul analyzed. I think in the U.S. 2T is the grade and it gives you a ton of wiggle room. Cohesion is directly related to the oils viscosity, adhesion has as much to do with the surface finish being lubricated as it does the oil itself.
I’m running it currently, and I am liking what I am seeing. It was the only oil that did poorly in lean testing, but has a super solid track record at normal ratios.Been using Motul 800 2T for over a decade now , no complaints.
Hot Saws 101 on YouTube a faller from Cali , been using it for 15 years , said he’s never blown up a saw using it,I’m running it currently, and I am liking what I am seeing. It was the only oil that did poorly in lean testing, but has a super solid track record at normal ratios.
He's the feller that broke out data sheets. Hp2, h1r, and 2t are at the top of the food chain chemically. Maximum adhesion, dispersion, etc. I think all 3 fair well in the carbon department too.Hot Saws 101 on YouTube a faller from Cali , been using it for 15 years , said he’s never blown up a saw using it,
It’s what Donnie Walker breaks all his saws in on and recommends.Hot Saws 101 on YouTube a faller from Cali , been using it for 15 years , said he’s never blown up a saw using it,
I must tune pretty good as i have used it at 32:1 in a real hot standup pwc and in my other hp two strokes at low ratios like 32:1 never had plug issues. It does leave a dusty soot around everything but never saw drool out of any equipmentSaber at 40:1 will foul plugs and leave drool behind if not tuned just right.
I know from having experienced this.
Belray H1R at 32:1 works really well to protect a saw engine when milling or stumping. It is a thick oil...that's plain to see when pouring it.
BUT....
In a smallish autotune or mtronic unit, it hurts performance....not just a wee bit either. I was using H1R at 32:1 in everything...and Julian @Redbull661 told me that I was handicapping my saw by using it. Naturally, I thought he was nuts. So, I bought some Yamalube 2R (a much thinner oil) and tried it.
In a ported 562XP, just switching oil increased cut speed 35%.
I still use H1R in big saws that are being used for torturous activities. But my usual oil is Amsoil Dominator at 40:1
I've noticed a little of that too in my MMWS261. What's your recommendation for a new oil?Sticky crap. Fills mufflers with goo.
