- 3:08 PM
- Apr 28, 2016
- Croatia
Although, we could subscribe him to any and all surveys, he seems to like them!Might wanna edit out your address on the letter there buddy.
Box-o used dent pullers incoming!View attachment 376558Bunch of damn hippies.
Yes.I took your advice....View attachment 37659240:1???
I'm in dunedin ! Yourself ?Where in the Land of the Long White Cloud are you mate?
Other end. Whangarei.I'm in dunedin ! Yourself ?
One thing I really liked about the Dominator over Red Armor is it readily mixes with fuel. When I use RA in my ratio-rite, I have to pour in little raw fuel and stir to get it to mix completely before going into my mix jug. Could be the base oils and viscocity differences.Sticky crap. Fills mufflers with goo.
In 4 stroke vehicles most of the wear from cold starts is from fuel (choke) washing oil off the bores and no oil pressure on initial start up. I can see in freezing conditions the above would be worse and last longer until the engine gets some warmth into it.I am interested to see how mixed 2 stroke oil is effected by sub zero temps. They say most of 4 strokes engines wear comes from start up and is accelerated in freezing conditions. Does starting saws in freezing conditions increase wear and letting it idle in those conditions be more critical?
Asmoil is good at getting oils to keep low viscosity at a sub freezing temps.
That was my opinion as well. As long as I can get the saw moving pulling it thicker oil doesn’t bother meRed Armor being thick can be a bítch to start a saw if it’s really cold.
BUT
That tells you it’s still in the bearings and on the walls
I have to warm my ported non decomp saws up in winter or leave them in the cab of the truckRed Armor being thick can be a bítch to start a saw if it’s really cold.
BUT
It must've about been 10 years now since I bought my first shindaiwa red armorRed Armor leaves a pretty sticky residue after it’s mixed with gas and has been spilled and reevaporated in my experience. I’ve gotten some muffler goo too, especially at 40/1 or 32/1 too.
I’ve also noticed is that it takes a few more pulls to start my saw if it’s been stored with RA. Like it’s gotta warm up that thick coating to get the piston moving smoothly. I’m in an uninsulated garage tho so it’s making me feel better about storing them in the damp/dry/damp environment.
Like any good oil, If it doesn’t blow up your top end and it makes you feel warm and fuzzy about your about your oil choices… that’s what oil threads are really about.
That and making fun of Stihl Ultra Hp
