jakethesnake
I Am The Snake
3:12 PM
Here & Now
I’ve heard of people running it in cars like that. I run it in small gas engines. Seems to help carburetors flowing between uses
not sure what I’m running now I think I’m out of the raisman full synthetic. I respected it. I’d buy again
Nutball
2:12 PM
Mt. Juliet, TN
Actually I run my gasoline vehicles on it too. With very good success. Good orl
So, gas oil is no good in a diesel, but diesel oil is just fine in a gas engine? Different additives in them, I think, so it would be nice to know what is and isn't good to do.
3:12 PM
I'm no expert on this, but from what I've read, you should use diesel oil in a diesel and non-diesel oil in gas engines.
The additives are different for a reason, and what is good for one is not always good for the other.
That does not mean you cannot get away with doing the wrong thing, it is just not the best thing to do.
farminkarman
I like the red & black ones
2:12 PM
Neenah Wisconsin
The only problem with running Rotella (T4-T6) in a modern gasoline vehicle is the zinc can ruin your catalytic converter over time...this is only relevant to those who have to pass emissions. Shell has reduced the zinc content in recent years, which is why @Mastermind is on the right track adding zddp for his older flat tappet engines. If you don't have a cat, or care about passing emissions, then Rotella is great to run in a gas engine.
3:12 PM
I’ve used the Rotella t4 15-40 for years. The cleaning properties are quite substantial. Wife had 250k on her Tahoe and started burning a quart every oil change. 3k miles on t4 15-40 and oil consumption stopped. It’s all my 02 Duramax has seen since new. Had to get fancy and run the t6 5-40 synthetic in the Ford
Duce
3:12 PM
Roscommon, MI
At 20F or below seems synthetic oils are easier on equipment. Switched hydraulic/trans to conventional new Holland oil, took tractor too long to warm so pump squealing stopped. Drained that day and filled with synthetic, problem solved. Tractor is mainly used for firewood and snow removal. Warmer climates would be different, I am sure.
farminkarman
2:12 PM
Neenah Wisconsin
I'm listening. T6 is better for cold weather then?
Yes, in the one that has winter duty, I run the T6 5W-40….then I don’t have to drain oil before winter….handles hot weather just fine too. The 15-40 is a pain to deal with when it gets really cold.
Duce
3:12 PM
Roscommon, MI
I guess we both need to move, so we can use cheaper oils!;)
Nutball
2:12 PM
Mt. Juliet, TN
Don't they put a cat on diesels too? My dad's 1996 dodge 2500 had one.
2:12 PM
I bought a NOCO 2500A booster. Holy hell....that sob spins the old 2640. Might not need to worry about oil viscosity. LOL
