- 9:16 AM
- Feb 5, 2016
- Glenside Pa.
Exactly. Even though 90 E-free is everywhere around me, my saws get canned. I don't burn wood or work with a saw. Property clean up and hobby. So they set months some times especially the vintage saws. Canned fuel keeps them happy.I can’t afford the canned fuel for my usage at work. Those saws get high usage anyway so they aren’t sitting for long with old ethanol fuel. But for some of my saws in my collection I don’t use for work I use the canned fuel. I can run a saw dry on it and have the piece of mind the fuel system stuff won’t go bad as quickly.
As to your overheat damage idea, I ran the trimmers hot enough under the load I out on them to melt and charr the plastic around the head.So just to clarify, you only observed carbon build up and removal in the exhaust port? I find the port doesn't get as dirty as a piston crown, and my main concern is the carbon getting to thick. Also, keeping the piston clean may help it stay cooler and trap more heat in the cylinder.
Next I'd like to see a test showing which oils or ratios protect best against overheat damage.
Maybe, in your environment, 6 months isn't enough for phase seperation to occur. I've also read that most fuel stabilizers do not prevent phase seperation. I've had trimmers here that were to be potential test units, that had the crankcase almost eaten through and there was a white ish granulated substance all over the effected areas. There was water and oil present. The fuel had evaporated. No idea on the time frame. Before E-free was available here I used Marine grade Stabil and started everything every 3 months tops year around and kept the tanks full. I never had corrosion but still had ruined fuel lines and carb diaphragms over time. A person's environment should effect how quickly phase seperation occurs.View attachment 302624 Maybe I’m lucky. The whole fleet behaves this way though
I pay about 1/3 that price for citgo air cooled [emoji16]I’ve been using this from Menard’s for $1.50 a bottle.....fight me.
You guys racing to the bottom on price lol.I pay about 1/3 that price for citgo air cooled [emoji16]
Sent from my moto g(7) power using Tapatalk
Hahaha yup!You guys racing to the bottom on price lol.
Another MI boy. NiceHahaha yup!
Are you from MI too?Another MI boy. Nice
Man dude. You use a lot of earlI'm sure there are better oils out there, but this oil has served me well. A box of 12 qts. will usually last about 8-12 months. That'll buy a lot of pistons and bearings paying $15 per gallon vs $60
My profile says nunya....Are you from MI too?
Hahaha yup. I cut trees for a living, so it adds up.Man dude. You use a lot of earl
